FYI - Bluetooth & MM Package Issue Resolved
Hey guys,
This is just an informational post in case this happens to any of you!
Well this morning, I plugged in my ipod as I usually do and it started playing like usual. Then after about 10-15 seconds it stopped playing. I unplugged it plugged it back in, turned car off and then on, same thing. I then flipped over to Sat Radio and AM/FM radio. NOTHING PLAYED!! I'm like WTF!!!
Now i'm already running late for work, finally drive to work in silence. I get to work, turn car off and let it sit for a few minutes, turn back on and try again. It will play and then I realized that it stopped playing once my blackberry connected to the car via bluetooth. So I disabled the bluetooth on my blackberry (Verizon Tour) and immediately the sound worked.
So I pulled the battery on my blackberry and reset it and all is working fine now. I'm not sure why this happened but it is an easy fix to reset your blackberry or bluetooth device.
Cheers
Cheers
Great, I did a search and found the answer I was looking for. My Blackberry was causing this to happen today. I will go try your method and see if it fixes my issue.
