No auto door locks ??
2009 C300 SPORT
Hey, everyone just noticed this the other day, usually the door locks with auto lock when you go above 10mph. But i recently noticed there not locking at all anymore unless you do it manually. What gives?
2018 E300 4MATIC Sedan
Setting automatic locking
Use this function to activate or deactivate
the automatic central locking. With the
automatic central locking system
activated, the vehicle is centrally locked at
vehicle speeds of approximately 9 mph
(15 km/h).
Press v or ^ to select the
Vehicle submenu.
Press ok.
Press v or ^ to select the Automatic
Door Lock feature.
Press ok.
The current setting Enabled
or Disabled is shown.
Press ok again if you would like to
change the current status.
Depending on the previous status, the
automatic central locking feature will
be Enabled or Disabled.
(15 km/h).
Vehicle submenu.
Press ok.
Door Lock feature.
Press ok.
2009 C300 SPORT
Ahhh though it was more indepth system programming, Thanks alot...This is what happenes when you give your parents to drive your car. They like to mess around with everything!
No problem, glad I could help !
By the way, did you know that if you register your car on the Mercedes Benz website ( owners online ) it gives you access to a downloadable copy of your owner's manual ?
Nick
Nick
A few different ones
I wonder if it is dependant on the key used, for example key 1 might have had it the settings for the doors to lock but key 2 wasn't so when you used key 2, it followed the settings of that key.
I know with my BMW & Corvette it works this way.
