Elbrus Wheels & sizes
2010 E350 SP / Honda Crosstour / prior vehicles - C32 modded / C300 modded / Lincoln LS modded
Ok this is the wheel I wanted. It's Elbrus copy of the Wald carried Mahora.
The Walds were pricey. Tire rack carries these but only in a 42 offset non staggered width of 8" wide. Also they are very inexspensive. Is quality an issue ? I really like them but will the car look funny with a 42 offset and 8" all the way around ?
http://www.tirerack.com/wheels/Wheel...%2FIce+Coating
Mercedes C300 Sport, BMW 745Li, VW Mk6 Golf TDI
Reps are cheaper cause they don't need to recover R&D investments and typically use inferior materials which can cause bending, warping, cracking of your wheels. If you're in a region with good maintained roads, not really an issue, but if you regularly commute through areas filled with potholes and uneven roads, could be hazardous.
1 Post
w204 - 350 N other white cars
i will also have a 42 offset all around.. hope it will come out how i will like it... my setup is not to go aggressive so i guess i might be ok..... i think those rims might look better if the offset are little more aggressive... just my 2 cent
