winter tires
Old Sep 15, 2009 | 02:38 PM
tommy1752003's Avatar
MB C230 4Matic
winter tires
hey guys
the tire sizes are different in the front and the back
any suggestions the set up that you will put on the car
same size all around or go with the stock size
Old Sep 15, 2009 | 02:49 PM
vic viper's Avatar
S213
Same size, this way you can alternate between front and rear.
Old Sep 15, 2009 | 03:19 PM
Peabody's Avatar
I'm going to peel my summer tires off my AMG 18s and throw winter tires on them. I've never really had bad front/rear wear differences and next spring I'll have new staggered AMG 19s.
I was thinking of getting Goodyear Eagle F1s, anyone have any experience with these? I used Pirelli Neros on my last car but I didn't like them very much.
http://www.discounttiredirect.com/di...14583&sw=false
Old Sep 15, 2009 | 03:57 PM
ctrider's Avatar
mercedes
Nokian all the way. i've had blizzaks but from my experience the nokians i had on my W203 and i was able to stop on snow as well as some very bad icy patches, i drive in CT so tthe winters are pretty rough here!
http://www.nokiantyres.com/
Old Sep 15, 2009 | 05:49 PM
Norm01's Avatar
2011 E550 Coupe
To add to this, I have a C300 4Matic with 17" staggered wheels. Would 16" steel rims fit (non-staggered) and what would be the appropriate tire size. Thanks.
Old Sep 17, 2009 | 06:45 AM
Peabody's Avatar
Norm look in your driver's side door jamb, there's the dimensions for your spare tire on a steel rim. I would stick with those dimensions if you want steel rims for your winters.
Old Sep 17, 2009 | 05:02 PM
whiteongrey's Avatar
'20 Targa 4 DD, ' 18 Volvo S60 T6
I have 2 sets of MB staggered 17" wheels / tires and RWD - 30 min DIY and the snows are on.
245/17/40 rear snows worked fine last year when we had the most snow fall since 1955 (when they started keeping records here) 45 min from the Rockies. Only a couple of very steep hills that I could not get up from a stop. Overall the stability / traction control does a great job.
IMO AWD and narrow profile winters are not needed unless in extreme snow conditions or have lots of wet snow 3"+ (in which case go for the narrowest tire / rim combo you can get) or drive in a very steep short hilly areas often.
I've owned several AWD cars and have run narrow profile winters for years on FWD and AWD. MBs great software is a real plus - not needing either any more. We have mostly dry snow rarely over 8" on the road at any time.
