Side Marker LED light bulb
08 W204
Wil this work for the side marker?
http://cgi.ebay.com/ws/eBayISAPI.dll...m=170381245128
will these give error code??
2008 C300 4matic Sport
if you are going to put LED exterior bulbs you need to make sure they have built in resistors... if they dont you will get an indicator in your cluster for a bulb out... the other way you can put LED bulbs in is to wire a resistor "in-line" with the lighting circut this will allow you to use any led bulb that does not have a built in resistor... but if you are going to wire resistors "in-line" you need to measure the resistance of the original bulbs for that circut
www.sylvania.com if you go to the main page you can click on a drop down for automotive lighting they list all bulbs for the 204
