Supposed to look like this ?
Old Oct 7, 2009 | 06:53 PM
BENZ LIFER's Avatar
2009 C300 SPORT 1999 CLK320
Wife totaled her C.
She's ok but car did not fare as well .
Glad we have air bags.
Looking for a deal on 2010
Old Oct 7, 2009 | 07:02 PM
Sportstick's Avatar
Another round of ICE
That actually looks like a fairly minor to moderate side swipe. It doesn't look like a major change in velocity. The side bags blew? The results of the FMVSS 214 compliance test typically produce significantly more passenger compartment intrusion, although I have not seen the C Class test photos.
The primary impact point seems to be just above the sill, and although the rear door seems to have a closure obstacle, the front and rear pillars and roof structure show no apparent deflection.
Of course, we are all glad she is OK, but the car seems to have absorbed whatever the source of the force was well, with relatively minor deformation. Do you know if the floorpan was involved?
Old Oct 7, 2009 | 07:03 PM
ShoremNJ's Avatar
ML 350-Black=Sold. New 08 C300 4Matic, Black/Black, P1, Ipod, Auto7speed, 10/10 hit 100,000 miles
Is the a rhetorical question?
Old Oct 7, 2009 | 07:13 PM
BENZ LIFER's Avatar
Not sure on floor pan
Insurance adjuster said he knew it was totaled from 50 feet away.
I looked at it and the post between doors was in bad shape .
He said it wasn't even close to being repairable.
Good new New car , Bad news 2010's are more $$$
Old Oct 7, 2009 | 08:27 PM
got_thang?'s Avatar
2008 C350
Sad to hear but glad your wife is okay.
Old Oct 7, 2009 | 08:34 PM
QC55's Avatar
C230 4Matic, SLK350
Most important thing is wife is ok. The car is always replaceable. Wife isn't!!
Will you be able to get the wheels back?
Old Oct 7, 2009 | 09:00 PM
Bobby204's Avatar
2001 R129 SL500, '08-'20 W204 C350
seems any time airbad is deployed, car is totaled.
Old Oct 7, 2009 | 09:43 PM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
Good to hear wife is OK
Good thing you are getting 2010 with all the new gadgets.
Old Oct 7, 2009 | 10:16 PM
451/443=EW's Avatar
C350 4Matic
Wow the car held up well, did just what it was supposed to do... protected your lady.
Old Oct 7, 2009 | 10:26 PM
Sportstick's Avatar
Vehicle ratings | News | Consumer brochures & videos | Research & stats | Laws & regs | Status Report newsletter
Mercedes C class
2009 Mercedes C class: good performance in front, side, and rear tests and standard electronic stability control
Frontal offset test results
2008-09 models 2001-07 models Technical measurements (driver-side occupant compartment intrusion and driver injury) for midsize luxury/near luxury cars Side impact test results
2009 models with standard side airbags 2006-07 models with standard and additional optional side airbags 2005 models with standard side airbags Technical measurements (structure, driver injury, and passenger injury) for midsize luxury/near luxury cars Roof strength test results
No roof strength tests have been conducted for this vehicle. Rear crash protection/head restraint ratings
See results for all Mercedes models Compare this vehicle with other current midsize luxury/near luxury car designs
Good Acceptable Marginal Poor
search helpsite index ©1996-2009, Insurance Institute for Highway Safety, Highway Loss Data Institute • copyright/use of images/linking policiescontact usprivacy policy
1005 N. Glebe Road, Suite 800, Arlington, VA 22201 USA | tel 703/247-1500 | fax 703/247-1588
Old Oct 7, 2009 | 10:35 PM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Write-off
Ahh, look again.
The wheel was pulled back, taking the entire rear with it. That's where the gaps come from above and behind the door. The car is now a slight U-shape. And with the bags blown, it's scrap.
Old Oct 7, 2009 | 10:47 PM
joshg1001's Avatar
2017 E300
frame is probably bent and such. was it her fault? glad shes okay
Old Oct 7, 2009 | 10:52 PM
Sportstick's Avatar
Originally Posted by RLE
Ahh, look again.
You're right about that rear wheel. Wasn't certain if it was body-in-white or suspension component damage causing the angulation. I wasn't able to pick up on the U-shape distortion, which would suggest the pan was cortorted. I would like to see a shot of the b-pillar with the door open. It may have run afoul of the manufacturer's guidelines for repair if the pan is involved. I know Saab has that requirement (learned that when my daughter's car was totaled). But, from a purely economic point of view, I certainly see sheetmetal, but the overall structure looks surprisingly intact for a total, figuring its about a $30,000 value. The preservation of the passenger compartment certainly is a wonderful result for the occupants!!
I've now seen a couple of comments about air bag deployment indicating a totalled car. This is not correct. Bag replacement does not cost anywhere near enough to justify a total, and some frontal impacts can result in blowing the bag, but not enough damage to toss out the whole car. Been there with another Mercedes.
Sportstick's Avatar
Unitized construction.....no frame
Old Oct 7, 2009 | 11:12 PM
RLE's Avatar
RLE
PERCENTAGE
You're right about that rear wheel. Wasn't certain if it was body-in-white or suspension component damage causing the angulation. I wasn't able to pick up on the U-shape distortion, which would suggest the pan was cortorted. I would like to see a shot of the b-pillar with the door open. It may have run afoul of the manufacturer's guidelines for repair if the pan is involved. ...........figuring its about a $30,000 value.
I think the adjuster recognized that the cost of repair would likely exceed the percentage that they use of the car's value.
Totalling it is a lucky thing for the owner since this amount of damage would have a very large influence on it's value after it's put back together.
When I traded in my '95 C280 the dealer wanted me to sign a document attesting that the car had never had any body repair. I think that any repaired wrecks go the auction since they likely don't qualify for a CPO warranty. And your trade-in value would be so far down it would take a strong light to find it.
Old Oct 7, 2009 | 11:50 PM
2nice4me's Avatar
2011 E350 4 Matic
I always wondered where the front passenger airbag deploys from? I could not see anything on the dash that would appear to popout. Any idea? just curiousity
And yes, glad the wife is ok, a car is just a car and thats what we have insurance for.
Old Oct 8, 2009 | 01:23 AM
JimPap's Avatar
2008 C300 Sport, RWD, US
Glad your wife's o.k.
Old Oct 8, 2009 | 01:54 AM
joshg1001's Avatar
2017 E300
actually comes out in a weakened part of the dash, usually a slit like opening. The bag pops out of there. same with the one for the driver. ever wonder why the entire cover doesnt hit your face?
Old Oct 8, 2009 | 02:20 AM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
My insurance company replaces a write off with a new car within 2 years. Best to check yours ?
Was the car still remotely driveable ?
Old Oct 8, 2009 | 10:24 AM
BENZ LIFER's Avatar
Thx for all the concerns for my wife !
Much appreciated.
She is bruised but considering impact came out very well.
The rear wheel was perpendicular to car after accident. They had to move it back straight to tow. With as strong as the impact, I would say a VERY safe car. That's why we will buy a Mercedes again.
Old Oct 8, 2009 | 11:08 AM
AMGTTV8's Avatar
2026 AMG GT63 Pro
first and foremost, glad you and yours were ok during the crash!!
any details as to the circumstances leading up to the crash (speed, direction etc?)
car performed very well!
Chris
Old Oct 8, 2009 | 11:32 AM
BENZ LIFER's Avatar
As she said "IT ALL HAPPENED SO FAST" . Going opposite directions , even police report is unclear. Still working out details. Could be 50/50 responsibility . Considering a 360* spin after impact I would say car performed well.
Old Oct 8, 2009 | 11:42 AM
AMGTTV8's Avatar
2026 AMG GT63 Pro
what did she get hit by though? car or truck?
Old Oct 8, 2009 | 11:48 AM
hutch300's Avatar
2022 GLE450
Glad your wife is ok... good to see the C's hold up
You should pull some of the little parts off... like maybe the foglights that break and exhaust tips... floor matts... nothing insurance would notice... and maybe the schatz parts
will insurance reinburse you for the amg's?
also do you still have your lux shift knob... i'd love one for my sport
good luck on your 2010 search!
Old Oct 8, 2009 | 12:09 PM
JimPap's Avatar
....the vultures are gathering.
