Quad Exhaust original parts
2 Attachment(s)
Maybe it's interesting for the people that want to put C63 Diffuser and a quad exhaust.
1) C63 exhaust A2044903621 https://mbworld.org/forums/attachmen...1&d=1255113926 2) Quad tips B66030870 https://mbworld.org/forums/attachmen...1&d=1255113926 |
The C63 exhaust seems fully compatible with C300 and C350.
Best Regards. |
Quad tips B66030870 replaces the single exhaust tips from the original exhaust of 300/350? This can be ordered from the benz dealer?
is this meaning there is a factory mod to do quad tips now?
Sorry for the confusión. This part is for W164 350, 320, etc... and yes it is factory, and can be ordered from the dealer/stealer.
I have checked the sizes of the tips are are the same of C63; the only think diferent can be the alignement. For sure it's an easier solution than the others seen... The other solution is puting the original C63 exhaust... has someone tested it? |
Originally Posted by festuc
(Post 3756506)
I called the dealer for the item number price was up of 1000 dollars
Originally Posted by Normandie4life
(Post 3757131)
1000 for the quad tips??
Nice find, but they are quite expensive. I checked online and they also sell for about 750 euro.
that much just for tips???? can't be
I've got a pair of tips for sale...
They are the same ones on all AMG 55 and 63 models. Price is $300 plus shipping. Send me a PM if anyone is interested. http://i181.photobucket.com/albums/x...o4/AMGTips.jpg http://i181.photobucket.com/albums/x...4/AMGTips2.jpg http://i181.photobucket.com/albums/x...4/AMGTips3.jpg |
1 Attachment(s)
As in a previous thread , I uploaded this pic of the AMG exhaust system from the C63, according to the tech guys in the dealership I took the car from, if you install C63 system w the center muffler, it will have an exhaust note that "drones" , they recommend you leave the C350 center res and install only the '63 mufflers and tips, I cannot back this up with a sound clip but am just relying on what the tech guys said. fyi:nix:
B66030870 dimensions
1 Attachment(s)
Hi Guys, I am hoping someone can help me here. Does anyone have dimensions for part number is B66030870. There is no stock in the UK and none of the dealers have dimensions for it either. I want to fit them to a W204 C320CDI.
I need to find out the following dimensions before I order the part; A. The total width of tailpipes from side to side. B. The overall length of the tips from exhaust connection end to the tip. C. The internal diameter of the pipe that connects to the rear exhaust box. I was told by a dealer that the rear box outlet on a W164 is 66mm which seems quite large. I will post this on the W164 forum too in the hope someone there can help. Thanks in advance, Teb |
I don't know why you need to the diameter's and so on?
I ordered my quad tips that look just like that and were made for w204's. Then all you need is the quad tip diffuser which has enough room for the two tips to fit on each side. Maybe I am missing something, but why do you need the sizes and all? |
Originally Posted by papashango
(Post 5507692)
I ordered my quad tips that look just like that and were made for w204's. Then all you need is the quad tip diffuser which has enough room for the two tips to fit on each side. Maybe I am missing something, but why do you need the sizes and all? Hi, diffuser is already fitted however I am using a non standard rear box and my vehicle is a diesel. When you say your tips look like this are they this exact part number? If not please could you provide details of the ones you got. I ordered some tips from a guy on ebay who had construted the y-piece and non mercedes tips and you`d be horrified at how they fitted. After getting them to fit they rusted horrifically within 3 weeks. Now he`s not playing ball or admitting they were his tips! I had only done 60 miles and the car was covered in my car port. These amg tips are very expensive so want to make sure they will fit. The exhaust guys here are useless and wont mod or construct anything. I even have 4 mercedes oval tips for someone to construct the y-piece and couldnt find anyone to do it. Going back to the dimensions I would assume the width is not an issue. The length could be because of the positioning of the rear box. The diameter could be a problem as with the previous ones I got. I think my box exit is 54mm. Any info you can provide will be helpful.:) |
Okay...
Here are the tips I bought http://www.ebay.ca/itm/230871227224#ht_500wt_1204 Doesn't look like the seller has anymore but I have seen other threads floating around where the person has exact same tips. I haven't had any issues with them at all. My shop had to cut the pipe a little bit to make them the perfect length and just welded them right on. I also had the x-pipe done. |
You can refer to this thread as well
https://mbworld.org/forums/c-class-w...t-product.html The seller seemed to had 2 pieces and this other guy seemed to have bought the second one. I would message the seller and see if he has anymore or can arrange for anymore. If not, look on ebay for something like that. |
