HELP What is the exact size rivet to use to put on the c63 diffuser brackets?
can someone please specify the exact size and type rivet they used to put the c63 bracket to the c63 diffuser that worked best??
thanks so much, & sorry for novice question
Can anybody tell me the EXACT size that worked for their bracket to diffuser application... want to avoid multiple trips to the hardware store and/or returns...
also, what is the best size grip to use along with the best size diameter???
would really appreciate the tips if anybody has them...
sorry for these amateur questions...
It may be because I have never used a hand riveter until now and I don't know what i'm doing, but how hard could it be? I put the skinny end of the rivet in the gun, put the fat end through both of the holes of the pieces that are to be fastened together, and I squeeze, right????
I think I need a bigger diameter rivet than 1/8"?? how did u get it to stay, it seems way to small to me...
but maybe i am using the riveter wrong???
i am real close to just pulling bolts out of my tools drawer if i cant find the right size soon though!
Sorry it took so long to get back to you. I had a couple of rivets lying around (luckily me). Unfortunately, I can't tell from the under side. BUT the rivet should need some force to get through the plastic hole on the diffuser (i.e. seem like a little large).
If worse come to worse the dealer should have them in stock for less than a dollar. I do not have a part number but they could just look it up on the EPC or walk to the part shelves and bring one out.
Sorry if this doesn't solve your quest.
