Sensitive tires?!?! LOL
Have any of you had issues with your TPMS warning light going off repeatedly?
and yes during winter/cold days the tire psi can drop few psi. warm tire will increase the psi at least 3-4 psi.
if you set the tpms with warm tires you will get the check pressure msg every time the tires are cold because the psi can vary up to 5-6psi.
Get a quality air pressure gage and check them yourself. You may find that one tire is leaking.
If they're all the same, then reset the system.
Maybe I need dinner and movie to bring them back to normal.....
