Am I the first in the w204 forums that has the backup camera wired as "always on"???
LOADED 08' C350 & 14' GLK-350 Diamond White (P1, MM, AMG Pkg, Ln Trkng, Htd Sts, Keylss Go)
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
I paid a dude $100 bucks to do finish the wiring and pop the command back in after I ripped up the car and mounted the camera because I don't have a soldering iron and have no experience with splicing wires and soldering...
He didn't even have to use the purple cable that goes to the reverse lamp or he did not even have to use an extra RCA extension. The included wires with the kenwood camera were more than long enough and the only cable outside the head unit area is the video cable going to the camera.
I know the camera pulls basically nothing to stay powered on 24/7, but I just wanted to check with the forum pros if there is anything I should be concerned about from not having the camera on switched power like everyone else...
I guess if I didn't drive the car for a month the battery might die but that will never happen.... It is nice having the camera sharp and focused the instant I shift into reverse instead of having a slight power up delay...
Anything else I should be concerned with for having constant always on camera power?
Rb
Rb
He wired it somewhere behind the command, not the cigarette lighter... I'm not sure exactly where tho sorry... Ya it is nice having the camera ready and focused perfect with no delay the instant u switch to reverse... And it pulls nothing as far as I know so won't kill your battery unless u leave your car for a long period of time..
The camera module and all conections were made behind the command when I was watching him, only the video cable that came with the kit went to the rear, no RCA extension had to be used
I can only think of premature failure of the camera, would be a possibility, being on all the time, what is the life expectancy, is it now shortened ?
u have the audiovox right? maybe kenwoods are a little different... but i think the main advantage is the clean wiring and not having to lose any signal strength by rigging up another rca and having to use a coupler and being able to use just the wires that came with the retail kenwood package
'08 W204.081; M 272.948 KE30; Colour Code#792
This is the first time I'm hearing about focus issues with the Kenwood CCD-2000 camera.
Mine has no focus issues I'm aware of, and the lag time to "on" status is not noticeably annoying. We're talking less than 0.5 seconds here! Besides, the lag time is equally dependent on COMAND flipping the screen over to the camera input (more or less).
Anyway, I don't see a point in having an always on setup unless you are using it as a replacement to the rear view mirror. I'd instead opt for a switched setting whereby you can turn it on at will, and leave it off if you don't care. You would have to hook it up as a video aux, and install a switch somewhere in the car.
If he wired it behind the command, why didn't he use something like the remote power so that it turns on and off with your command unit? All the benefit of "always on" and none of the questionable wiring.
