De-badged, Diffused, Spoiled, and Flapped!
The diffuser comes with directions which might make anyone wonder if the part will really go on...they sound daunting! But, with two people, the whole install took about 15 minutes start to finish and you can see the fit is excellent.
The flaps went on very quickly, but there is a slight gap on the vertical projection. The material can be pressed against the fascia, but slightly bows out. Attachment is easy and does not require any drilling or permanent changes, so they can come off and leave no damage. But, in the Spring, I think I will ask MotorWerks to urethane them flush against the bodyside.
Enjoy the show!
I have to get those mud flaps to put on in the winter here too. Haven't decided between the $90 black ones or $250 for color coded. Seems like a lot for painting but they would look so much better by blending in to the body. ebay is pretty much the only spot to buy those still correct??
And is that an OEM trunk spoiler?
These mods look really good on your car!
Maybe I'll need a set of mudflaps!
Mudflaps from HiTech on Ebay.
Thanks!
http://www.jbspeed.com/servlet/the-M...204/Categories
EDIT: Nevermind. I found JBSpeed's thread with the roof and trunk spoilers.
