The ESP system in the new mercedes c class
So could someone please explain what the ESP is and when/how to use it, or when not to use it?
Thanks in advance for your cooperation.
You don't actually have to do anything yourself really. What it does is have the computer in the car brake each wheel individually when you are in a slide to straighten you out again - mainly to help avoid/minimize the damage to you and the car in the event that you are headed for a crash.
Some people like to disable it to slide the car (and press that button on your dash), yet it does not fully disable it. It only limits it somewhat in comparison to other manufacturers' systems.
But yeah, you don't need to do anything with it. It's a safety aid in your car.
The other two programs are ABS (Anti-Lock Braking Systems), and ETS/TSC (Electronic Traction System). Those use the brakes to keep traction during braking and acceleration respectively.
ASR doesnt provide more friction but its better in finding the grip that any surface can provide, so with the same initial speed ASR would still do better. It wont climb forever because at some point there wont be enough friction but if the friction is there ASR will be better in finding it than your foot.
Or do you think it is a combination of the kinetic energy the car initially has plus the available friction, where friction alone is not sufficient to keep the car climbing at steady speed? In this scenario ASR would be needed to gain the maximum effort out of the kinetic energy and limited friction.
