Old Jun 8, 2015, 03:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
Print Wikipost
Trunk Spoiler Installation
Old Dec 26, 2009 | 08:43 PM
Asianguy's Avatar
C300 Sports 4-Matic
I received my 3 pieces Brabus Spoiler from JBspeed today.
I live in NY and it's like 40 degrees here right now. No heated Garage so the question is, is it okay to install the spoiler now or wait till it get to what temp?
I am thinking of putting a portable heater in the garage and run it for 48 hours but it's not cost efficient lol.
BTW i am using 3M Double sided tape instead of Glue, does the weather really matter if i am using a 3M tape? or a warm weather only advisable if you use a Glue for curing reason?
Any suggestions, would be greatly appreciated.
TIA.
Old Dec 26, 2009 | 08:55 PM
charliele729's Avatar
09' E350 AMG Sport, 09' C300, 03' Honda S2K
I think the 3m tape is fine for all weather season, otherwise why would factory use it. I install mines in the garage with the garage up and it was cold, not sure about 40 degress cold but, once installed I just made sure I didnt let it get wet or let it cure for a day or so.
Old Dec 26, 2009 | 09:14 PM
Asianguy's Avatar
C300 Sports 4-Matic
Did you use any kind of adhesive promoter?
Old Dec 26, 2009 | 10:41 PM
Sportstick's Avatar
Another round of ICE
I got the AMG spoiler from JBSpeed and my customizing shop strongly advised using a bead of urethane as well and letting it set indoors (I would guess 60 degrees minimum) for 24 hours before driving. It's now as solid as a rock.
Old Dec 26, 2009 | 11:18 PM
jmsspratlin's Avatar
Very FAST!
Any pics?
Old Dec 27, 2009 | 05:35 AM
imboom's Avatar
I installed it in 60-degree weather with a healthy amount of 3M Exterior tape. For the first few nights, I put blue painter's tape to kind of push it on just in case. It's been solid as a rock since. I can't even budge it.
Old Dec 27, 2009 | 06:32 AM
Peabody's Avatar
Exclamation
Originally Posted by 3M
Ideal tape application temperature range is 70°F to 100°F (21°C to 38°C). Initial tape application to surfaces at temperatures below 50°F (10°C) is not recommended because the adhesive becomes too firm to adhere readily. However, once properly applied, low temperature holding is generally
satisfactory.
Source
Old Dec 27, 2009 | 08:53 AM
Asianguy's Avatar
C300 Sports 4-Matic
Originally Posted by Peabody
I found this on Youtube, 3M Adhesion Promoter, i might have to try this even on a cold weather and use blue tape to hold them for a few days. 4 days weekend is coming up next week, so that will be a good time to do this:
http://www.youtube.com/watch?v=0HnZ8xJnYLI
Old Dec 27, 2009 | 10:28 AM
Sportstick's Avatar
Originally Posted by jmsspratlin
Any pics?
Not of the actual process, but here is the great result including the bodycolor Euroteck diffuser and HiTech mud flaps!
Sorry the wiper arms are up....car wash!!
Attached Thumbnails Trunk Spoiler Installation-img00013-20091201-1524.jpg   Trunk Spoiler Installation-img00012-20091201-1524.jpg
Old Dec 27, 2009 | 02:35 PM
alexlev's Avatar
C204
My trunk spoiler and roof spoiler are both held on by 3M double sided tape. For some reason the corners begin to peel off over time . . this is the second time around now so I'll have to redo everything once the weather gets warmer.
Old Dec 27, 2009 | 02:42 PM
Teck's Avatar
C 320 CDI 4M W204 / C43 AMG (W202) / C 220 CDI T (S203) / ZX-10R Ninja
http://https://mbworld.org/forums/attachment.php?attachmentid=173214&stc=1&d=1261927 493[/IMG]
Like the diffuser and also the color of your ride
Old Dec 27, 2009 | 02:46 PM
Sportstick's Avatar
Thanks....when I bought it, the search went across 5 states near Michigan and we found 10 cars with manual trans. 3 Red, 3 White, 3 Black, and one Palladium Silver. That made it easy!
