Timing belt or timing chain?
Old Jan 27, 2010 | 11:39 PM
mistersir's Avatar
2010 C300 4Matic
Does the W204 have a timing belt or timing chain? If it's a timing chain, does that need to be changed with the water pump down the road, or will it last the life of the car?
All my previous cars had timing belts and I hated changing them because it costs so much $$$.
Old Jan 28, 2010 | 12:34 AM
charliele729's Avatar
09' E350 AMG Sport, 09' C300, 03' Honda S2K
I believe it is chain, If you take a look inside under the oil cap, it looks like there are bike chains in there.
Old Jan 28, 2010 | 09:25 AM
matthew121170's Avatar
2012 E350 - Cabrio; 2017 GLS 450
They are chains, and it is my understanding that they don't need to be changed unless they fail. Of course if the chain fails, you are going to have bigger issues...
That's my understanding...
Old Jan 29, 2010 | 07:06 PM
pfphipps's Avatar
2003 E320
Your car has a timing chain and it should be replaced when worn, not when it fails. This is usually well over 100,000 miles on a Mercedes engine (with the exception of one V8 engine in the early 80s). It has nothing to do with the water pump.
Old Jan 29, 2010 | 07:40 PM
ah ha...see i stand corrected. thanks!
Old Jan 29, 2010 | 08:44 PM
mistersir's Avatar
2010 C300 4Matic
That's good to know. I always felt timing belts were ticking time bombs, as they can fail by age and not necessarily by mileage.
Old Feb 2, 2010 | 09:13 AM
Derspeed's Avatar
X3 and 2012 C coming soon
You would think something would have replaced timing chains and most certainly belts by now. I remember insalling timing gear drives in motors some time ago. It was not on cars with overhead cams, but surely someone could come up with a way to make it work. Gears and spinning rods maybe?
