c350 - slugish after tcu reset
Old Feb 1, 2010 | 07:25 PM
ricgreen1's Avatar
c350
Unhappy c350 - slugish after tcu reset
I bought a used 2008 c350.
After reading a few posts about the car on this forum, I decided to try the following tcu reset procedure.
Steps to Reset the TCU. Resetting the TCU will reset transmission to factory shift points and the car will 'relearn' your driving style.
(1.) Turn the ignition key to the on (not start) position.
(2.) Press the gas pedal to the floor and hold for five seconds.
(3.) Turn the key to the "off" position (don't remove the key), then release the gas pedal.
(4.) Wait at least two minutes for TCU to reset.
After doing this my transmission became extremely sluggish. Before when I was in sport mode, the car would jerk (violently) from a dead stop when I slammed on the gas pedal. Now it seems to take its sweet time.
I'm wondering if this is normal, and if it will fix itself with time.
Richard
Old Feb 1, 2010 | 08:26 PM
ldtCapitan's Avatar
C300 Luxury
Maybe it's in the "relearning" process. Why exactly did you reset it?
Old Feb 1, 2010 | 09:14 PM
Royce118's Avatar
15 E200CGI SPORT
When did you reset it? Doesn't sounds right but probably like ldt said it could be the learning process.
Old Feb 1, 2010 | 09:55 PM
ricgreen1's Avatar
c350
I did it on Friday evening. I guess I thought that this would improve the performance. But in fact it did the opposite.
Richard
Old Feb 1, 2010 | 10:00 PM
Royce118's Avatar
15 E200CGI SPORT
Richard
Try waiting for a few more days. Could probably just be the learning process. Anyway if it still doesn't work I'll probably try doing the reset again or taking it to the dealer.
Old Feb 1, 2010 | 10:53 PM
Niti24
Guest
Posts: n/a
i tried those steps a while back but it didn't work on my c300. Everything is the same. i have actually tried it a number of times
Old Feb 1, 2010 | 11:16 PM
I am Jeff's Avatar
Steel Grey Metallic C63!!
Why are you resetting the TCU yourself? Even if it is a 2008, it should still be under warranty. I had mine reflashed because my SA told me that my software wasn't exactly a perfect match with the ECU. I'll take his word for it because it complete fixed my sluggish, reverse lag issue.
