subwoofer install question
Old Mar 24, 2010 | 07:16 AM
...its-low...'s Avatar
c300
I am about to install a 10" jl in my car. I was wondering the easiest route for the power wire coming from the battery under the hood...going to the trunk.
TIA-chris
Old Mar 24, 2010 | 08:48 AM
Norm01's Avatar
2011 E550 Coupe
Right behind the battery there's a main grommet, go through one of the hole indentations around the grommet, you can't go through the middle with the factory wires as it is all sealed. you will end up in the passenger kick plate and it is easy from there back.
BTW, a 10W6 Prowedge fits perfect in the back, the W7 is too high and will hit the trunk crossbar. I used a mono 500V2 amp it has lots of bass, pull high level signal off of rear sub especially if you have the HK system.
Old Mar 24, 2010 | 10:44 AM
Spec_Davis's Avatar
W204 Color: 090 / 1999 Honda Civic EX / 2003 Acura TL
what is your setup and how are you installing it?
