OEM Rear Diffuser Removal Help!
Old Mar 26, 2010 | 06:58 PM
Illusive's Avatar
2012 C63 AMG
So I'm reading up on some of the DIY's for the C63 diffuser install, and it sounds like removing the stock rear diffuser is really simple. Well I'm stuck. So far, I've removed the two 10mm hex screws on either side, but I can't seem to get any of those damn tabs to let go to remove the bumper. Anyone who's taken the stock one off, am I missing any screws or is there a certain way I need to pull or push the tabs or diffuser to get it out? I've tried pulling down and out to no avail and I even opened up the tow hook opening to get at a tab and I couldn't get it to budge. Any help would be greatly appreciated!
Old Mar 27, 2010 | 12:53 PM
Illusive's Avatar
2012 C63 AMG
Seriously? No one even with all of those quad exhaust mods?
Old Mar 27, 2010 | 01:13 PM
Sportstick's Avatar
Another round of ICE
Sorry! I would like to help, but I did not do the remove/install when I had the new diffuser installed...took it to the shop and it took two guys to put on the new one.
Old Mar 27, 2010 | 02:48 PM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
There are two more hex head screws behind the OEM exhaust tips, the easy way to get to then is by removing the tips.
Good luck!
Old Mar 27, 2010 | 08:40 PM
Illusive's Avatar
2012 C63 AMG
Got it figured out, thanks tanktube! I found a different DIY that showed those two torx 20 screws, but the instructions were vague so I wasn't sure if they needed to be removed or not. I have the Remus exhaust installed, so there is little to no room to work in there, managed to get it out with a small ratchet, 1/4" socket, and a torx 20 bit.
Old Mar 27, 2010 | 09:58 PM
alexlev's Avatar
C204
What are you planning on doing? Are you replacing the OEM diffuser?
Old Mar 28, 2010 | 07:24 PM
Derspeed's Avatar
X3 and 2012 C coming soon
I believe he bought the Eurotek CF diff from a member. Looking forward to seeing it installed.
Old Mar 28, 2010 | 07:54 PM
Spec_Davis's Avatar
W204 Color: 090 / 1999 Honda Civic EX / 2003 Acura TL
just installed today! Quad tip will be installed this week. =)
Old Mar 28, 2010 | 09:06 PM
alexlev's Avatar
C204
Is that a dual exhaust diffuser?
edit. Did a quick search and found an image. The Remus exhaust is going to look great with the diffuser
Illusive's car is shaping to be one of the nicest on the forum.
Old Mar 28, 2010 | 11:51 PM
Illusive's Avatar
2012 C63 AMG
No, I was going to wrap the OEM diffuser with 3M Ni-Doc CF material. Didn't work out and I got a lot of left over CF. I did my side mirrors with them, but I still have a bunch left. If anyone can use it, let me know. I really want to get the Euroteck CF rear diffuser, but I can't justify the $600+ price they want for it. I'll have to wait until the price goes down before I do this mod.
Old Nov 20, 2015 | 02:46 PM
FABi0_C63AMG's Avatar
2010 C63 AMG 4DR
nice diffuser. where did you get it?
