what grade gas do you guys use for C300?
btw, thanks for all the fun facts but I was only questioning whether lower octance fuel burns at a slower rate (what you said), or whether it ignites at a lower temperature and also whether using higher octance fuel than recommended by the manufacturer will result in better gas mileage (which I say is not true).I think my previous posts answers all questions; higher octane gas than the manufactuer recommends does in fact result in better MPG in some vehicles according to Car and Drivers test results with the BMW M3.
(See my above post).
(The 2001 - 2007 BMW M3 with the S54 engine is one such car. Car and Driver magazine dyno tested a car and found that the power output increased as the AKI was increased up to approximately 96 AKI. Also, these systems can result in HIGHER FUEL MILEAGE MPG for cars designed for the HIGHER OCTANE fuels.)
While Porsche does reccomend fuel additives like Techron, Mercedes Doesn't. Soemthing to do about having an adverse effect elsewhere along the chain and drying out some lines. But I'm no expert...
Usually using a higher octane fuel than recommended by the OEM will not result in higher MPG, but in a few vehicles, esp. high performance ones, it will.
I have managed to find a Sunoco station near work that is 3.85 for premium 93 octane, and same price for credit!
Purchased 2013 c 300 a week back.
My dealer told me to use 85 normal gas. he said new engines are designed to handle the normal gas.
Is it true ?
On the inside of my gas filler door, it tells me that I can use E85 in this car..
Typically on E85 you may receive less fuel economy, but the lower cost usually outweighs the cons of fuel economy resulting in net savings. Fuel systems and lines need to be designed to support E85 and should only be used in cars that specify they can support it on the fuel door (which you said your door states it can).
As far as regular gas goes, Mercedes engines are designed for premium 91 octane minimum (most premium gas at stations is 93 octane). However, the engines have knock sensors which can detect premature detonation (due to lower octane) and Adjust timing, etc to prevent engine knock or damage to the engine. I would recommend sticking with 93 octane regular gas for best performance and fuel economy, but you should definitely try out e85 if your car can support it and see how you like it.
It's not recommended to mix the two, so that is a disadvantage for e85 gas as not many stations (at least in northeast region) carry it. You should try to let your fuel tank run as low as possible before switching from e85 to regular pump gas (and vice versa).
Hope this helps.
I always use premium gas. 91 where I live!
Hope this helps.
Thank you.
Hope this helps.
That being said, you are not correct on the mixing. The car is designed to run on pure E85, 91+ Octane, or any combination of the two.
I haven't yet used E85 as the price is higher than 93 Octane here and it is less powerful... But if you have a Flex Fuel W204 you can use it in any combination you want. According to Mercedes...
What do you think we think of you for asking a question that already has been posted on MBWorld numerous times without searching for an answer first?
You are #1. Thats what we think of you.
