Adjusting the low beams height on a 08 C300
Hi folks, I'm new to this forum and sorry if there is a post already in the search just didn't find one.
I was wondering if you can explain to me how to adjust the height of the low beam on a 08 C300. I called my local Merc dealer and they wouldn't tell me and wanted to charge $138. If you guys have a known youtube link or picture of where it's at it would be greatly appreciated.
Also I installed aftermarket HID's in it and found out that the wiring is actually in the headlight housing rather than just in side the engine bay and a connection that connects to just the blub. So I cut a little square piece out of the headlight housing so I can run the wire out to the ballast. I covered up the little hole with some electrical tape so moisture doesn't get in. This should be ok right?
Thank you all so much
2008 C300 4matic Sport
