is it a full kit? i might be interested.MBWorld Fanatic!
That is a great price for a brake kit (after all- they are made by Brembo). I'm probably the only one the would not want the AMG logo on them. Maybe I'm crazy.
i know that retrofit the c63s brakes needs the following parts
FRONT BRAKES
A2044214798 x1 CALIPER - PARTS KIT, LEFT
A2044214898 x1 CALIPER - PARTS KIT, RIGHT
A0004214765 x2 BLEEDER VALVE - WITH DUST CAP
A0014210991 x2 SPRING
A0004215174 x2 TS BOLTS PARTS KIT
A2214210014 x2 PULL ROD
A0169900601 x2 BOLT
A0044208920 x1 BRAKE LINING/TS DISK BRAKE PAD - PARTS KIT
A0019900814 x4 BOLT - CALIPER TO STEERING KNUCKLE M14x32
A1715400617 x1 BRAKE WEAR SENSOR - BRAKE LINING WEAR INDICATOR
A2194210212 (or A2124210512) x2 BRAKE DISC - FRONT
A2044211320 x1 PROTECTIVE PLATE - LEFT
A2044211420 x1 PROTECTIVE PLATE - RIGHT
A2094280135 x2 BRAKE HOSE - FRONT LEFT AND RIGHT
A2043321901 x1 STEERING KNUCKLE - LEFT
A2043322001 x1 STEERING KNUCKLE - RIGHT
A2043220122 x2 PIVOT PIN
A2119810227 x2 ANGULAR CONTACT BEARING
A2113570508 x2 FLANGE
A1403570572 x2 NUT
A0019904203 x8 BOLT - BEARING AT STEERING KNUCKLE
A2113331114 x2 BEARING - STRUT
A2043304911 x1 CROSS STRUT - LEFT
A2043304911 x1 CROSS STRUT - RIGHT
A2045401817 x2 SENSOR - RPM SENSOR, FRONT
A2044013902/B66030098 x2 DISC WHEEL-5SPOKE WHEEL FRONT AXLE 8Jx18 H2 ET45
A0035400217 x2 (optional) TIRE PRESSURE SENSOR - TPMS CHECK 433.92MHZ
REAR BRAKES
A2044234198 x1 CALIPER - PARTS SET, LEFT
A2044234298 x1 CALIPER - PARTS SET, RIGHT
A0014210791 x2 SPRING
A0004214274 x2 PIN - PARTS KIT
A0189900001 x4 BOLT - CALIPER TO WHEEL BEARING
A0054202520 x BRAKE LINING/TS DISK BRAKE PAD - PARTS KIT
A1715400617 x1 BRAKE WEAR SENSON - BRAKE LINE WEAR INDICATOR
A2044230412 x2 BRAKE DISC - REAR
A2044014002/B66030099 x2 DISC WHEEL-5SPOKE WHEEL FRONT AXLE 9Jx18 H2 ET54
do you include all these parts in your package? or you offer a special adapters?
FRONT BRAKES
A0169900601 x2 BOLT
A1403570572 x2 NUT
REAR BRAKES
Yes, we can do that!
We use FedEx international ground shipping!
Quote:
Originally Posted by albert101
This is very tempting, do you ship to Canada?
You are not the only one!
we have customers painted the caliper orange or red and put BRMEBO logo, painted the caliper bright blue and put Carlsson .... all kind of Combo
Quote:
that is sick! Can i put my name on it? lol j/k
Quote:
FRONT BRAKES
A0169900601 x2 BOLT
A1403570572 x2 NUT
REAR BRAKES
LOL - no response from vendor...Originally Posted by w204maniac
i know that retrofit the c63s brakes needs the following partsFRONT BRAKES
A0169900601 x2 BOLT
A1403570572 x2 NUT
REAR BRAKES
guess they missed all of these costs in their offer price
ExploreThe parts listed is to make the C63 brake conversion in Mercedes' way!
The solution we offered here is to upgrade a BBK in Brembo's way!
picture here answer 85% of the questions!
Quote:
FRONT BRAKES
A0169900601 x2 BOLT
A1403570572 x2 NUT
REAR BRAKES
A0169900601 x2 BOLT
A1403570572 x2 NUT
REAR BRAKES
Quote:
Or we can do blue with Brembo Originally Posted by AkaSigFreak
blue is so niceee but i like the silver look =)
and now Mercedes AMG has this GOLD calipers for Ceramic brake
I personally like it very much! it will go nice with black or Gray cars
Quote:
will it cost extra for the Gold color?
What color would look best with a white car w/o looking ricey?Originally Posted by DCTMOTORSPORTS
and now Mercedes AMG has this GOLD calipers for Ceramic brake I personally like it very much! it will go nice with black or Gray cars
Just wondering....how exactly does that picture answer the questions....? Those of us who are not quite sure about the preceding steps to a BBK could use an explanation.Originally Posted by DCTMOTORSPORTS
The parts listed is to make the C63 brake conversion in Mercedes' way!The solution we offered here is to upgrade a BBK in Brembo's way!
Now here's the question of the year....will this kit work for us 4matics>?
Quote:
We don't know since we have not install or test fit on 4matics model yet!Originally Posted by phranksmbz
any owner in bayarea want to test fit can schedule a time with us, we are located in Mountain View, CA
Yellow is nice for white car!
Red never go wrong since Brembo always come with RED
Silver is safe! AMG color!
Quote:
Already sold one set!
thanks for forum members' support!
^^^ Hot damn, somebody jump on this plz.
Yes this price on a BBK is amazing will be ordering mine very soon from DCT =)
No... most of the parts posted will be included. If you look at that parts list, it also includes C63 wheels, TPMS sensors, wheel speed sensors, etc. that are not required. Originally Posted by WWMIndy
LOL - no response from vendor...guess they missed all of these costs in their offer price
The parts list also includes the steering knuckle and lower control arm assembly. The C63 front calipers will not mount directly to the standard C-Class knuckle because the bolt spacing is 20mm different. The DMS kit includes a mounting bracket adapter to address this issue.
thank you!
Originally Posted by YYZ-E55
No... most of the parts posted will be included. If you look at that parts list, it also includes C63 wheels, TPMS sensors, wheel speed sensors, etc. that are not required. The parts list also includes the steering knuckle and lower control arm assembly. The C63 front calipers will not mount directly to the standard C-Class knuckle because the bolt spacing is 20mm different. The DMS kit includes a mounting bracket adapter to address this issue.
Sorry, I'm not too familiar but is that the bracket to adopt the AMG brakes to the standard W204? Do you guys make that bracket yourself or it's from a supplier?Originally Posted by DCTMOTORSPORTS
we had the maching shop made these for us!
