Wheels
Old Jun 15, 2010 | 11:54 AM
donedharm's Avatar
c240
Wheels
Need your helpWill the wheels and tires on a 2009 c350 work on a 2002 C240?Thanks
Last edited by donedharm; Jun 15, 2010 at 07:51 PM. Reason: I pit the wrong year in on the C240,SORRY
Old Jun 15, 2010 | 01:18 PM
C300Sport's Avatar
2008 C300 Sport 6 Speed Manual, 1953 Chevy Bel-Air, 2015 Audi allroad, 1963 Chevy Apache
The offsets are way off so the wheels/tires would be pretty sunk into the body on an older c240.
Old Jun 15, 2010 | 01:29 PM
bigigg's Avatar
14' CLS550
The only way the wheels will work is with some thick wheel spacers.. Like 15mm.. I'm not even sure if the lug pattern is the same
Old Jun 15, 2010 | 03:47 PM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
The lug pattern are the same on all Mercedes 5x112. It's the offset that makes all the difference.
Old Jun 15, 2010 | 08:05 PM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Wheels
Aside from the obvious offset problem, I think the wheel bolt threaded diameter is different. So, will the 203 bolts work with 204 wheels? The conical seating surface must match.
Old Jun 18, 2010 | 08:27 PM
jtpmedic's Avatar
2010 C-300 Sport
IF you need a 15mm spacer as was stated before, the OP will need longer lugs anyways...
Old Jun 18, 2010 | 10:52 PM
bigigg's Avatar
14' CLS550
well length and diameter are two different things.. i believe our lugs are 17mm.. i dont know too much about the w203 so i can really help much
Old Jun 19, 2010 | 07:38 PM
RLE's Avatar
RLE
Diameter
I am aware of the difference. The W203 bolt diameter is less.
Old Jun 21, 2010 | 11:24 PM
Normandie4life's Avatar
Black C300
im selling my wheels if anyone is interested pm me
