'Peeling' rubber lining
Old Jul 6, 2010 | 12:37 PM
dandelos's Avatar
2008 C350
The rubber lining at the center console/screen is 'peeling' upwards slightly (see picture). If pressed down, it sticks for about 10 seconds and then starts to slowly peel off again.
Has anyone encountered this problem? If so, what glue (I assume the solution is some kind of glue) should I use?
Old Jul 6, 2010 | 01:16 PM
Krytech's Avatar
2014 Ghibli S Q4 & 2008 C350
What year is your car? I would suggest taking it the dealer and having them replace the part that is failing.
I don't think you would want to glue that part because I think it needs to separate if the head unit ever needs to be pulled out for any reason.
Old Jul 6, 2010 | 01:19 PM
jctevere's Avatar
2012 C250 Coupe
+1, that warping is due to heat and stretching. And that part is not meant to stick to the A/C ducts as they must be removed to remove the head unit. I would suggest bringing it to dealer if under warranty. Or if not, then glue is possible, but it would mean extra steps or complications if you want to do a command retrofit down the line.
Old Jul 6, 2010 | 01:26 PM
dandelos's Avatar
2008 C350
Thanks, guys. It's a 2008, and it's still under warranty.
Old Jul 6, 2010 | 01:39 PM
justthinking's Avatar
2008 C300 Sport, 2010 RX350 AWD
just get some 3m office use double side tape and re-tape the rubber pad yourself..
mine had the same problem after I have UMI installed as the factory glue lost its stickyness after been removed..
all you need to do is remove the pad, clean the back of any glue residual and apply the double side tape around the edges..
mine has been sitting flush for the past yr and half w/o any problem..
Old Jul 6, 2010 | 01:48 PM
brettybenz's Avatar
08' c350 sport
My 08 is doing this too when i got into the car after a beach day I noticed it, ticking me off
Old Jul 6, 2010 | 11:21 PM
MBnewby's Avatar
2008 C350 Sport
My 2008 has the same problem...doesn't bother me too much though.
Old Jul 6, 2010 | 11:53 PM
kdu's Avatar
kdu
2009 C300 Sport
Yea same with my 09, only happens after a hot day. Probably going to bring it to the dealership this weekend, even if it is such a small fix.
