AZN Optics 5W5 Canbus LEDs
Old Oct 22, 2012 | 10:27 PM
  #701
JDubya3's Avatar
2009 C63
Got my license plate LED's today in the mail; anyone has a DIY to install the *******s on a 2009 C63?
Old Oct 22, 2012 | 11:51 PM
  #702
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
I thought I did. It's not that bad. The trickiest part was removing the trunk trim in order to access the housing for the bulbs. You have to get behind it so try to remove as much of the trunk lining as possible at the beginning.
Old Oct 23, 2012 | 12:05 AM
  #703
Feel free to message me if you have any questions.
Old Oct 23, 2012 | 11:59 AM
  #704
dadangman's Avatar
'09 C350
hey Azn optics, i'm interested in getting two sets of 5000k for the eyebrown, and two amber LED turning signal. Can you price it out for me PM me please?
thanks a lot!
Old Oct 25, 2012 | 01:40 PM
  #705
Okay, folks, here's the DIY. I actually did it on my own before I found this DIY from the website I used to order them.
http://store.ijdmtoy.com/Mercedes-W2...-DIY-a/198.htm
My additional comments would be to have pliers. There are several anchors for the trunk pieces that snap together and it's much easier to squeeze those anchors and reverse feed them through the holes where they snap in.
Example, when you remove the chrome trunk trim, you should have pulled back as much of the trunk liner as possible so you can really get in behind there. Use pliers and detach as much of the trim as possible. Then on the outside, pull out and down to release it. If there's any resistance, STOP. Go back behind the liner and try to find an anchor you missed. If you release all of the anchors, it'll be easy and you won't risk scratching your car.
Once that is done, you have to also release the anchors for the black plastic part where the lights are housed. When its loose, pull it down and you should be able to pop out the old lights and pop in the new ones. Be careful with the snaps because one broke during my installation and I had to wait to get replacement. Also, keep some electrical tape handy in case the light isn't quite snug against the connector.
Old Nov 4, 2012 | 06:18 PM
  #706
finger360's Avatar
2016 C63s AMG
Hey, i'm interested in getting two sets of the 5000k LEDs for the eyebrows and two amber LED turn signal LED bulbs. PM price for me?
Old Nov 4, 2012 | 11:39 PM
  #707
AZN Optics's Avatar
SPONSOR/MBworld Guru
PM sent
Old Nov 7, 2012 | 03:05 PM
  #708
vmartinez83's Avatar
Benz C300
Just ordered mine...can't wait! Anyone have some installation tips?
Old Nov 7, 2012 | 04:43 PM
  #709
Look at my post 4 posts up...
Old Nov 7, 2012 | 05:11 PM
  #710
AZN Optics's Avatar
That is a different product and installation process is different. Please remove that link to not confuse people on my vendor thread as it is also a competitor product.
These are straight bulb replacement LEDs that are not as difficult to install. There are other DIYs posted, but for your eyebrows, you remove the twist dust cap, then pull out the socket which is pressure held. If you can't get a good grip with your fingers, needle nose pliers help. Do not pull by the wire, no matter how tempting it is as you run the risk of stripping the wire. Then you simply pull out the bulb and replace. I've included instructions that detail how to check for proper polarity. Also if you plug it in the wrong polarity too long, your ecu will shut power to the socket reading it as a dead bulb (as there's no need to power a dead bulb). Just simply power cycle your vehicle by turning the engine on and off to reset the socket.
As for the trunk light, all you need to do is pop a few pressure tabs holding the liner down as well as the screws on the center plastic tab. Then all you have to do is reach in from behind the liner (doesn't need to be fully off, just enough to reach your hand in), find the socket, twist it to unlock, and pull out the stock bulb. Then just replace it with my wedge LED, check polarity, and click it back on. You don't need to do any rewiring or anything on the outside.
Old Nov 9, 2012 | 03:54 PM
  #711
Jestech27's Avatar
2012 C300 Sport
I can say that the driver's side city light on a 2012 C300 sucks to get out. I'm struggling with it as we speak. Passenger side was easy, but there's no room to get your hands in there on the driver's side.
Old Nov 9, 2012 | 04:04 PM
  #712
AZN Optics's Avatar
angled needle nose pliers should go a long ways towards helping.
Old Nov 12, 2012 | 04:31 PM
  #713
Shark_Face_Gang's Avatar
2010 Mercedes-Benz C300 4MATIC Sport
How does the 8000k look with stock bi-xenons? I know the 5000k matches closer but I like the slightly blue tint, just wondering if it'll look too odd with xenons.
Old Nov 12, 2012 | 07:24 PM
  #714
AZN Optics's Avatar
I actually have plenty of customers who prefer 8000k with stock xenons to give brows some contrast and not just one glob of white light.
Old Nov 12, 2012 | 08:06 PM
  #715
I have 8000k eyebrows with 6000k lights.
Old Nov 12, 2012 | 08:11 PM
  #716
Good I was hoping it would give a little disparity between the two sources. In that case I'll be ordering several sets later tonight. Thanks for the input!
Old Nov 12, 2012 | 10:09 PM
  #717
xXHotelCrazyXx's Avatar
2008 W204 Sport
Mike, I sent you a PM with a problem I am having
Old Nov 12, 2012 | 11:42 PM
  #718
Crazy4Cars's Avatar
W212 E350 AMG E63 Pack.
check your Pm
Old Nov 14, 2012 | 05:29 PM
  #719
MKay's Avatar
C350
Just ordered 2 sets from ebay, can't wait to receive
Old Nov 14, 2012 | 06:35 PM
  #720
AZN Optics's Avatar
AZN Optics be closed Thanksgiving Week (Nov 20th-24th). We will still process electronic orders, but shipping of order will be delayed till Monday Nov 26th.
Old Nov 17, 2012 | 08:48 PM
  #721
BathingHobo's Avatar
2009 C300 Sport
Thanks for the great customer service, I really appreciate it. I attached 2 pictures to give you guys an idea of what the colors look like...
The first picture has what I believe to be 4200K from what AZNOptics told me. The best color to describe this is "minty green." It looks greener in person than in the picture.
The second picture has 2 different LEDs. The one on the left is 5000K but the older version (I think version 2.) It has a hint of violent/blue in it. The one on the right is version 3 I believe, and it's more of a ice/glacier white. That one is suppose to be 5000K too. I don't know why they are different colors even though they are suppose to be both 5000K. Maybe AZN Optics can answer that if you guys were curious?
Attached Thumbnails AZN Optics 5W5 Canbus LEDs-2.jpg   AZN Optics 5W5 Canbus LEDs-1.jpg
Old Nov 17, 2012 | 11:44 PM
  #722
AZN Optics's Avatar
4500K has some yellow injected in it to give it a paler white color. However, the eyebrow housing has a natural bluish tint built in and when you mix yellow with blue, you get green. The V2 5000K and V3 5000K should be the same as they're from the same CREE stock, just different die size. However, for the V2, how is the condition of the LED? I have a control unit from our old V2 and compared to the V3, looks the same when plugged in, so not sure if there was any damage that your V2 has?
Old Nov 17, 2012 | 11:51 PM
  #723
2009 C300 Sport
Ooops I meant 4500K not 4200K.
I attached a pic of the V2 if you wanted to see it. No biggie. It doesn't look that good so I'm assuming there is damage to it. Good thing I got the gel version of the V3.
I couldn't upload this pic from my computer for some reason so I had to use a site to upload it. Sorry, it's super big.
Old Nov 18, 2012 | 08:03 AM
  #724
BlackjackM's Avatar
2018 E300 Lux, 2006 Corvette Z51, 2015 Mercedes ML350 (wife's)
I installed the azn optics v3 5000k in my '13 c250 coupe and they look great!
Old Dec 23, 2012 | 01:21 PM
  #725
Project C's Avatar
MB C250
Hi Mike , im Piers from Malaysia. my ride C250. after reading this forum, im thinking upgrading headlight from stock 4300k to philip Diamond vision 5000k. (Need your advise).
I wish to order either 5000k or 8000k led for my ride eyelids (Any suggestions?).
~i believe now is Version 3 led in stock and with gel (withstand Heat).Correct me if im wrong...
Ps: How long does it takes for me to receive my goodies? and how should i order from you?
