AZN Optics 5W5 Canbus LEDs
Old Oct 8, 2014 | 08:34 PM
  #901
AZN Optics's Avatar
SPONSOR/MBworld Guru
Originally Posted by Eric DeCastro
just at first. i kept switching around and when I was about to give up and put the stock ones back in, one at a time they turned on.
Odd. Glad it's working now though. Checked polarity and power cycled the vehicle I assume? Only thing I can think of is either bad contact or loose wire if you pulled the socket out by the wire.
Old Dec 2, 2014 | 07:39 AM
  #902
W209W's Avatar
W209
Hi,
I am looking for W209 W5Ws at 5000k
Do you have anything like that?
Old Dec 2, 2014 | 12:28 PM
  #903
AZN Optics's Avatar
Originally Posted by W209W
Hi,
Do you have anything like that? What's the price with shipping to Lithuania (PayPal)
Please send me email to bizdev AT bizmajors and com as you don't seem to be active here
This is what you'll want: http://www.aznoptics.com/index.php?m...products_id=81
International shipping will be calculated when you put in your mailing address during checkout.
Old Dec 2, 2014 | 11:21 PM
  #904
ickdeep's Avatar
'13 M5 | 08 C300 (Sold)
Do you have an LED for the rear seat lamp? I used some for the front but the rear seat set is different.
Old Dec 3, 2014 | 02:15 AM
  #905
AZN Optics's Avatar
you mean the rear dome? That should be a 41mm festoon in the center bulb. Yes we do have that.
Old Dec 3, 2014 | 02:26 PM
  #906
ickdeep's Avatar
How much are those?
Old Dec 3, 2014 | 02:36 PM
  #907
AZN Optics's Avatar
Originally Posted by ickdeep
How much are those?
$10/unit. We typically sell by the set on our site, but just PM me your PayPal email and I'll invoice you. Have these in 5000k and 8000k.
Old Dec 12, 2014 | 11:03 AM
  #908
RLpolo2014's Avatar
Toyota Tundra & C300
What do I need for my wife's 2011 C300? I just want the headlights to match the LED fogs... tks!
Old Dec 12, 2014 | 12:37 PM
  #909
AZN Optics's Avatar
So you're looking for low beams? Or eyebrows? Low beams use H7 HID kit, eyebrows use 2 sets of 194 wedge LEDs.
Old Dec 29, 2014 | 07:56 PM
  #910
inittab's Avatar
none
I need LEDs for my 2012 C300 parking lights. They are currently stock W5W 194. Will your 5W5 LEDs work? I need them to match the same color as Sylvania ZXE H7 which are 4200K color temp.
Old Dec 29, 2014 | 08:03 PM
  #911
AZN Optics's Avatar
Yes, they'll fit and work just fine.
The closest color match we have to that is our 5000k which is a pure white color.
http://www.aznoptics.com/index.php?main_page=product_info&cPath=1_4&product s_id=81
Old Dec 29, 2014 | 08:08 PM
  #912
inittab's Avatar
none
You were quick on the response. Thanks
How do I do I place an order? What would you recommend I do about my H7s hight and low beam? Does your LED HID function of headlights?
Old Dec 29, 2014 | 08:22 PM
  #913
AZN Optics's Avatar
You can purchase directly from our site at the link provided. As for your high and low beams, we carry Morimoto Elite HID kits. LEDs are not recommended for forward projecting lights in housing not designed to properly capture LED spread. They'd work, but you'd get reduced throw distance with dark spots. The H7 LEDs would be ideal for locations like fogs which aren't relied upon for road illumination.
Old Jan 13, 2015 | 08:36 PM
  #914
ickdeep's Avatar
How much are the license plate LED?
Old Jan 14, 2015 | 12:45 AM
  #915
AZN Optics's Avatar
1 set of 194 wedge LEDs $19
Old Jan 16, 2015 | 06:54 PM
  #916
Funkwagen's Avatar
2009 C63 AMG, 2010 C250 4Matic Sport
How bright would the H7 LEDs be in comparison to say some silvania silverstar ultras?
Old Jan 16, 2015 | 07:53 PM
  #917
AZN Optics's Avatar
Not sure what the lumen count is on the silverstars, but our H7 Plasma LEDs are 600LM.
Old Jan 16, 2015 | 08:03 PM
  #918
Funkwagen's Avatar
I don't know what the regular lumen count is for average car headlight bulbs, do you think the LEDs would work for low beam applications, or are they mainly geared towards use for fog lights?
Old Jan 16, 2015 | 09:55 PM
  #919
AZN Optics's Avatar
They can be used for low beams, but aren't recommended because housings not designed specifically for LED light spread will have some dark spots where there's no light on the bulb. You'd have reduced throw distance, even though they're technically brighter than halogens. It just comes down to how the light is reflected forward.
Old Apr 1, 2015 | 09:21 PM
  #920
B Heals's Avatar
2010 C300 Sport
Hey Michael,
After doing some research in here, I just wanted to run what I think I need by you before I make the purchase. I have a 2010 C300 Sport with stock lights. If I want to do everything, I'll get the H7 HID kit for the highs and lows, and 5 pairs of the wedge 194s for my brows, fogs, sidemarkers, and license plates? Does that sounds right? Do you recommend the 5000k or 6000k for the H7, and which wedges match up best?
Old Apr 2, 2015 | 12:22 AM
  #921
AZN Optics's Avatar
Originally Posted by B Heals
Hey Michael,
Your fogs actually use H7 bulbs, not 194 wedge. Everything else is correct. I warn you about HID for high beams though. Due to the nature of HID bulb warm up cycle, you'll lose the ability to quick flash someone ahead of you. If you're just going to use high beams for road visibility, then it's not an issue.
As for color, this is personal aesthetics. 5000K pure white will be clean and classy, while 6000K/8000K is still white, but with a slight hint of blue that's more sporty. Your call.
Old Apr 2, 2015 | 02:48 AM
  #922
B Heals's Avatar
2010 C300 Sport
Really appreciate it man. Thank you!!
Old Apr 2, 2015 | 03:08 AM
  #923
Doa's Avatar
Doa
W205
use 6000k , matches the color of the DRL and most eyebrow/fog LED's
Old Jun 15, 2015 | 02:53 PM
  #924
gtu's Avatar
gtu
2013 Mercedes C250 Coupe Sports Plus
Hello Michael,
I have a couple of questions. I am looking to replace the interior lights of my Mercedes C250 Coupe 2013 2dr to a an LED bulbs. Please advice the price as well as confirm the LEDs will fit in the front and rear domes without any problems and the bulbs won't press on the lens causing a resistor plate contact after installation? Also, I am thinking to replace some of the exterior lights if you offer any options too?
Many thanks
Old Jun 15, 2015 | 04:10 PM
  #925
AZN Optics's Avatar
Originally Posted by gtu
Hello Michael,
Many thanks
For your interior, it should be all 194 wedge bulbs with the exception of the single rear dome center bulb that uses a 41mm festoon. Our V5 194 wedge units will not have any clearance issues.
A full kit includes front footwell, front dome, vanity mirror, door puddle, trunk, glove box, and rear dome. That's a total of 5 sets 194, and a single 41mm festoon. Exterior also uses 194 wedge for the parking light and sidemarkers. Let me know what you want and I'll put together a package price.
