need dome help here
Old Jul 21, 2010 | 05:11 PM
gorica79's Avatar
C180 AMG
need dome help here
when i drive my car i feel a lot of vibrations from left to right..
i dont know if its from the uneven surface,but driving gets me very tired..
in the same roads i dont get the same vibrations with my bmw 318
my front tires are 225/45/17 while back are 245/40/17
continental contsport3
why back different from front?
you think this difference has to do something with the vibrations?
i checked continental site and they reccomend 28psi front 33 back whilw in the fuek tank says 32 front 33 back..which i should follow??
do you all have this vibrations from left to right?
Old Jul 21, 2010 | 06:09 PM
Sentosa's Avatar
C200 Estate Kompressor W204, 2018 GLA 220d
Different sizes front and back probably means you have wider wheels on the rear. Tyre pressures seem low. I usually run mine about 38-40 with those width tyres but in 18". You could try putting a little more air in them as per your fuel tank and see if it makes a difference to your vibration.
Old Jul 21, 2010 | 06:30 PM
gorica79's Avatar
C180 AMG
it was 32/33 and i change it to 28/33 to check
nothing..still get this vibrations..actually is more like shaking than vibrating..there is not any noise at all..it just feels like im in aboat not in a car..left and right..
Old Jul 21, 2010 | 06:36 PM
Sentosa's Avatar
Unless someone else on the forum can offer any ideas I would take it in and get the front wheels aligned and balanced and have the front end looked at.
Old Jul 21, 2010 | 06:51 PM
Peabody's Avatar
yeah, I was going to say use the tire inflation on the door, and have your tires balanced.
