Kevin Benz Coil Overs has arrived !
![](https://mbworld.org/forums/images/ranks/veteran_marine_corp.png)
I think that stance is right on, now you just need to have those rims repaired or touched up. So how is the ride as compared with stock?
08 c350
adizon, those are stock tires with stock 18s
jkoehn, i think i have the one with the aluminum struts, they look aluminum lol
yullie, the ride is harder but the handling is amazin, after seeing results on the eibach sway bars i might consider this.
and zankok wat size spacers would you recommend?
W204, W220, S15 Silvia
depends on the specs of your current wheels are and what out come you want it to be
for it to sit flush ermm
my wheels now sits +45 and 9.5" width and it sits flush my stock was +58 and 8.5"...
so the difference in spacings are 58-45 + (9.5"-8.5")*2.5 / 2 = 13 + 1.25 = 14.25mm..
yea you need + 15mm spacers to look aggressive
#32
