7" inch monitor with audio 50
class c cdi 200 w204 12/2009
Hi I imported c class cdi200 12/2009 w204 from germany, it already has audio 50 aps cd navi with 4.9 inch colour display ( option 525) , I would like to have 7 inch display A20482046979F45 (black) 7" monitor.
Do I have to change also the Operating unit with DVD changer (ECE) A2048703596.
or the audio 50 aps can display with 7 inch...sorry about my english
2012 C250 Coupe
I wan unaware that they had different sized monitors?
To my knowledge (not positive) the command system and the screen are two different components and are only connected through one cable from the screen into the rear. My guess is that you could replace the screen with a new 7" one as long as the connector is the same?
But like I said, this is just speculation and common sense. If there is one thing I have learned with Mercedes Benz, its to expect the unexpected. Perhaps asking MBUSA or a service advisor if its possible and what would be needed is a good start. (I just wouldn't have them do it if its not complicated as they will bang you over the head with the price).
2009 C350
i believe he's talking about switching up from a standard screen to the pop up MM screen.
you can read more about that here: https://mbworld.org/forums/c-class-w...m-writeup.html
W204, W220, S15 Silvia
http://www.youtube.com/watch?v=O5NYp1_rGXo
He changed the screens only and remained the original sucky MM player, and used aftermarket players for the screen
i already have audio 50 aps cd navi with 4.9 inch colour display ( option 525) , I would like to have 7 inch display A20482046979F45 (black) 7" monitor.- about switching up from a standard screen to the pop up MM screen.
Can I just buy 7 inch display A20482046979F45 (black) 7" monitor and just plugged, do I need to do or buy something else
