help me with wheels problem
Old Sep 2, 2010 | 01:24 PM
a7med606's Avatar
AMG gts
i installed 19 inch brabus wheels on my c200k
but the problem is the wheels are very wide for my car
they are out of the fender by 2 inches
the size of the wheels or 19x9.5 for rear and front i think is19x8.5
and my problem is the rear wheels are touching the fenders
what can i do to avoid touching ??
i need to lower the car also because its higher than before
Old Sep 2, 2010 | 01:54 PM
Derspeed's Avatar
X3 and 2012 C coming soon
Sounds like the offset is too low. What is it?
Old Sep 2, 2010 | 01:57 PM
a7med606's Avatar
AMG gts
what is the offset bro ??
Old Sep 2, 2010 | 03:07 PM
97W202's Avatar
2006 C230 6speed/14 C63
uh oh
where did u buy your wheels from? was it online?
go back to the website. ur same wheels.. and look for "offset" or "ET".. there should be a number with a + sign.
Judgin by width seems like your in the VERY low 30's or high 20's... my guess.... 27.. let us know.
Old Sep 2, 2010 | 04:24 PM
Azn_C300's Avatar
Mercedes C300 Sport, BMW 745Li, VW Mk6 Golf TDI
Did you buy them through brabus or a shop? Or did you buy them second hand? If through a shop, I'd take them back cause your offsets are way off if it's 2 inches outside your fender and there's no way you can fix that (short of widebody). Basically the wheels you got are not the correct spec for the car. You can't just look at width and diameter when fitting wheels. And if the car is sitting higher than before, that's probably cause you went with larger size wheels without going lower profile tires.
Old Sep 2, 2010 | 08:19 PM
C300Sport's Avatar
2008 C300 Sport 6 Speed Manual, 1953 Chevy Bel-Air, 2015 Audi allroad, 1963 Chevy Apache
Originally Posted by 97W202
uh oh
That's exactly what I was thinking. You really should do your homework before buying wheels or any other mod to your car. Hope you get this worked out well without it being an expensive mistake.
