Portable HD via USB - is there a 120 GB limit?
Old Sep 23, 2010 | 05:21 PM
DavidM's Avatar
C 280 4Matic
Hello guys,
I have tried searching, but unfortunately, I could not find answer.
I have new 500 GB filled with cca 300 GB of music. My previous 120 GB HD with 110 GB of data was working ok. But with new HD, Command seems to be able to read only first 120 GB worth of folders listed alphabetically.
My question is, if there is a limit build in Command or if any of you guys is using more than 120 GB worth of data with no problems.
If so, will Command require some kind of reset, to learn new HD capacity?
Thank you for any kind of advice.
David
Old Sep 23, 2010 | 05:35 PM
blue00r6's Avatar
2017 C43
I hope you legally purchased all of that music!
Old Sep 23, 2010 | 05:55 PM
C300S 6MT's Avatar
C300, 330i, MDX
Old Sep 23, 2010 | 08:29 PM
jaeguyoon's Avatar
08 c350
how are u connecting the hdd via usb?!?!
Old Sep 24, 2010 | 04:43 AM
DavidM's Avatar
C 280 4Matic
I have Media interface (code 518 in MB price list), which has USB, iPOD connector and AUX if i remember correctly (I never used other than USB).
Old Sep 24, 2010 | 09:14 AM
mfwade's Avatar
C300
DavidM,
What is the part number of the cable/s you are using? I have 2 individual cables. 1 for the USB connection and 1 Y cable with the iPod/iPhone connector along with the AUX jack. It is a pain to switch between the two and would like them to be all on the same connection to the car.
Does the USB connector power the 120G HD or are you using an alternate source of power?
I will try my 500G HD over the weekend and post my results.
Old Sep 25, 2010 | 02:31 PM
DavidM's Avatar
C 280 4Matic
Originally Posted by mfwade
DavidM,
I have 3 separate cables. Part numbers are:
A 204 827 03 04 F30-USB 08.08/8389 20
A 204 827 04 04 F30-iPod 08.08/8389 20
A 204 827 02 04 F30-AUX 08.08/8389 20
It does power HD, it is 2,5 inch HD. 120 GB one was same type, only smaller capacity. It is broken now tho.
I have tried reset of Command but I can still see only first 120 GB. Please let me know, if you have any luck with your 500 GB. Thank you.
David
Old Sep 25, 2010 | 06:23 PM
len56's Avatar
C350
yes at that!
Old Sep 27, 2010 | 12:24 AM
mfwade's Avatar
C300
DavidM,
I have tried my 250G HD and am pleased to announce it works. I formatted the drive on my Mac using the "MS DOS" format and set it up for 1 partition "test". The "MS DOS" format on the Mac is the Windows equivalent of "FAT32". I copied over about 40G of music and was able to browse the partition and play the music.
Next I will try my 320G and 500G HD's (need a place to dump the files) once the drives have been cleaned up. Stay tuned!
Marvin
Old Sep 27, 2010 | 01:26 AM
Diesel Benz's Avatar
DavidM,
Marvin
It isn't the hard drive size only but also how much data (music) you have on it. Fill the 250 GB drive first before testing larger drives.
Old Sep 27, 2010 | 11:43 AM
Beausoleil's Avatar
E350
I think this could be right. My manual (for a C207, admittedly) talks of up to eight directory levels with up to 1000 tracks, so check if you have exceeded these limits in increasing the capacity of the drive. I do remember once seeing a list of portable drives tested by MB on one of their European sites and can't remember seeing anything as big as 500GB but this could be because they were not around when the list was compiled.
Old Sep 27, 2010 | 04:29 PM
eminnet's Avatar
Audi A4 1.9 TDI 2002, MB C200 CDI 2004, MB C220 CDI 2009
Here is the list of supported HDD's :
http://www.mercedes-benz-mobile.com/...re.php?sub=hdd
or at least what they tested and I see it goes up to 500 GB.
Please post here the working configurations for 5.1 .aac, .wma formats you use.
