Car Temperature
Old Oct 1, 2010 | 06:41 AM
dewydang's Avatar
C300
Car Temperature
My 2010 c300's temperature runs a little high. The needle is always in the hot side of the gauge. is everyones car like this or should i be worried? thanks for helping!
Old Oct 1, 2010 | 06:54 AM
JFOUR's Avatar
2008 C300 Sport 6MT X-Pipe
Mine seems to run between 1/2-3/4 up the guage. I thought that was kind of high until I read a few discussions here about it. It seems that is normal.
Old Oct 1, 2010 | 07:10 AM
dewydang's Avatar
C300
so it IS normal. okay. i got scared there a little bit.
Old Oct 1, 2010 | 08:02 AM
Samieee's Avatar
C
My car's temp goes to roughly 90 Celcius
Old Oct 1, 2010 | 04:25 PM
louiet3's Avatar
2009 C300 Sport Palladium Silver & 2012 GLK350 4matic Black
Check the water pump area if you have splatters of coolant.
I had the same problem and it turned out that the gasket on the water pump was defective and caused coolant to leak. They replaced the water pump under warranty.
Old Oct 1, 2010 | 04:31 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
This is normal. Lots of cars have it designed to stop perfectly in the middle so no one gets flustered, Benz chooses to do things differently. 90C is fine. The car will tell you if it overheats.
Old Oct 1, 2010 | 04:47 PM
MBnewby's Avatar
2008 C350 Sport
totally normal
