Old 06-09-2015, 01:05 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
Print Wikipost
accessing menu to increase max volume
Old 11-04-2010, 10:17 AM
cole79's Avatar
2009 mercedes c300
i recently saw a you tube video.. that allowed me to access menu on my radio.. that allowed me to raise my max volume... i forgot how to do it and cant find video.. can anyone help please..
Old 11-04-2010, 02:15 PM
mike_benzc300's Avatar
White 2010 C300 Sport
Secret menu: push and hold: Hang up (end) , 1, and # at the same time
Old 11-04-2010, 03:54 PM
08SEA300's Avatar
08 C300 Sport
Which adjustment in the secret menu adjusts the max volume. There was quite a bit to choose from.
Great post!!
Old 11-04-2010, 04:42 PM
Samieee's Avatar
C
Great post!!
Keep sifting through the options. There should be an audio section
Old 11-04-2010, 06:18 PM
IgorDj's Avatar
'13 C300 '14 E63S '08 E92 M3
is this true?
i never knew about this, i was wondering why the volume was so low
Old 11-04-2010, 06:44 PM
Blazeitup123's Avatar
W205 c400 sport
its as real as it gets. works on the 7in and 5in screens.
Old 11-05-2010, 10:20 AM
TaxEsq's Avatar
2013 BMW 528Xi; 2010 C300 SportW4 - sold; 1964 230SL
+++1
Old 11-05-2010, 11:31 AM
08SEA300's Avatar
08 C300 Sport
Quite a few volume options. Entertainment, Phone, TA (?), and there was another.
Oddly enough, none seem to raise my volume. Am I doing something wrong?
Old 11-06-2010, 12:14 PM
NewtwoMB's Avatar
MB C220 Sport W204, 18" AMGs, Grey lthr, xenons, p'ktronic, HKardon, Comand nav.
Sound system volume
I don't think this facility works on the Harmon Kardon Pro-Logic premium sound system option - I tried....!
Old 11-06-2010, 03:49 PM
whacko77uk's Avatar
ML320 Sport (2009) & C250 CGI Sport (2010)
Worked perfectly on my 2010 w204... move the lmax volume level under the sound / entertainment menu all the way upto 85... Now to add a flat sub and upgrade the fronts... The question is JL-TW5 or Rockford Fosgate P3S-12 but dont know what to do for the fronts.
I am amazed at the sound quality between this and the Comand HK sound I have in my ML... Especially via the iPod interface....
Old 11-11-2010, 06:10 PM
Acapulco Bill's Avatar
2010 C300 Sport
@whacko77uk: Many, many say these are the speakers to get, and I agree, fantastic sound, easy install
Infinity Kappa 60.9s for $110/pair
http://www.amazon.com/Infinity-609CS...9508934&sr=8-1
and here are Infinity 6032 for the rear doors (they are COAXIAL)
http://www.amazon.com/Infinity-Refer...9509008&sr=1-1
As for a sub, neither of those you mention are really efficient (less than 86 dB for 1 watt), go for something like the Polk Audio MM 1040, its cheaper and almost 6 dB more efficient (needs 25% the amplifier power of your choices).
Old 11-11-2010, 11:48 PM
2010 C300 Sport
The options in this secret menu, do not "raise" your maximum volume, only balance various inputs to make the outputs more equal. The maximum volume is determined by the performance of the output amplifier section (only Audio 20 here, not HK as NewtwoMB comments), which has a limiter. For your experimentation, you can play the radio or a CD, and keep turning up the volume with the front round volume knob - after a certain point turning the knob provides no increase in volume, the amp has reached its limit. Its well done actually, as it limits when the amps output reaches a predetermined distortion, sounds like 10% THD. Those who like it "as loud as it gets" should turn the volume knob (or steering wheel controls) up until the volume stops increasing, then back it off a bit to reduce the distortion without reducing the maximum volume.
Several posts complain about LOW volume. Why is it LOW? It is only the iPod? Is it the Aux? Is it the Bluetooth? If you can be more specific, some solutions could be posted as it sounds lie the problem cannot be solved changing the preestablished settings in this secret menu. Low volume from the iPod in particular (and bad EQ) has several causes, if the problem can be described, solutions will be posted.
Old 11-12-2010, 11:13 AM
bnam's Avatar
2009 C300 Sport
Bill,
How can I balance out the volume amongst the various inputs so that I don't have to change volume while switching from ipod to radio to cd, etc (I have Audio 20)? Currently, the ipod level is lower.
Thx,
B
Old 11-12-2010, 02:03 PM
2010 C300 Sport
This weekend there is some time for checking if the Radio and CD can be balanced. The iPod has several options, however three questions:
1.- Is the iPod connected through the AUX or through a MB iPod Interface?
2.- If you have the Interface, is there an iPod Amplifier attached?
3.- If you have the iPod amplifier, is it from Germany or China?
Old 11-13-2010, 02:14 AM
bnam's Avatar
2009 C300 Sport
The ipod (actually iphone 3GS) is connected thru the MB ipod interface that came with the car. I don't know about an amp? How to check?
Old 11-13-2010, 10:35 AM
2010 C300 Sport
Several preliminary comments are necessary here:
1.- Volume between the radio and CD - this should be preset at a "0" point (i.e. maximum radio voltage output equal to maximum CD output at +6). Radio voltage output on an average signal doesnt vary much in FM, this can vary in AM of course. Tje problem here is that CDs, especially the early produced ones from analog tapes, can vary greatly in their volume level, some are pegging their maximum volume and other were released up to -20 dB lower. There is no way to correct for this difference, other than the normal volume controls.
2.- iPod volume - recommended setting is to first disconnect the iPod from the connector, set the volume to "8" and Set the EQ to "POP". This will help the output preamplifiers of the iPod by not overdriving them (such as at "10") and the EQ "POP" setting is Mercedes own recommendation. Reconnect the iPod.
3.- In the Sound section of the Audio unit, get to Volume and make sure this is on "Boost" (not "Standard".)
4.- At this point switching from the Radio to the iPod (Aux vs CD) should produce equal volume with equal clarity.
5.- If this is NOT the case, or if you think the iPod sounds "muddy" or distorted, or a much lower volume level than the radio, then you will need to look for the iPod amplifier.
Here is a diagram. To check, pull out the bottom of the glove compartment, some like to remove the lower panel, or both. The iPod interface is the long rectangular-aspect box. Here is a photo of the iPod amplifier.
6.- The two cases here are: a) there was no iPod Amplifier included with the iPod Interface installation (should have come included in the cost, make sure they get one from Germany), or b) you have an iPod amplifier, and it is sourced from China, and is of defective manufacture. Get the one from Germany, same part number, a world's difference in quality (hey MB, WTF?) See images in previous post in this thread.
Old 11-13-2010, 10:52 PM
bnam's Avatar
2009 C300 Sport
In the sound section I could not find anything that had "Boost". THe options were IIRC
Ent Volume
Tel Volume
TA Volume
Equalizer
Under Ent Vol, there were only low and high settings.
BN
Old 11-13-2010, 11:34 PM
2010 C300 Sport
The Standard vs Boost setting is in the normal user menu controlled by the silver rotary knob on the center console: Turn the Audio unit on, and push the CD button on the dash.
On the central display, the bottom row has "Aux - Volume - Sound". Since this part of the thread is about getting the iPod to balance volume-wise with the radio, make sure "Aux" is selected and not the CD.
The next menu "Volume", push the knob and a choice of either "Standard" or "Boost" is available. Choose "Boost". The last section "Sound" has Treble, Bass and Fader shelving.
The object of this exercise is to insure that all elements of the inputs to the Audio system are in their standard configurations, to help determine if there is a deficiency that must be further adjusted in the "secret" menu.
Before changing any of these "secret" settings, for iPod users it is important that other situations, such as an absent or defective iPod Amplifier, are not the cause of low volume.
For those who use an iPod through a minijack and the regular Aux input, the previously mentioned settings of iPod Volume = "8", EQ = "POP" and Volume = "Boost" will insure the iPod is at its optimum level before any other adjustments.
Old 11-14-2010, 05:07 PM
bnam's Avatar
2009 C300 Sport
Hmm... in Aux mode, with iphone plugged in, the bottom row only has Aux and Sound. Does not have the Volume option. What'd going on here?
B
Old 11-14-2010, 07:23 PM
2010 C300 Sport
Do you have the retractable 7" MM screen or the fixed 5" screen?
Old 11-14-2010, 07:40 PM
2010 C300 Sport
Old 11-14-2010, 11:26 PM
bnam's Avatar
2009 C300 Sport
fixed 5" with the Audio 20.
B
Old 11-15-2010, 12:25 AM
2010 C300 Sport
Will take some photos and post tomorrow. Do you have the Audio 20 original manual?
Old 11-15-2010, 11:12 AM
2010 C300 Sport
Volume & Boost
Attached are photos of the Volume section and Boost selection, which is active as shown by the DOT preceding Boost. Please refer to post #18 above. Later there will be a new thread about the Parametric Equalizer and Volume settings, for those interested in exactly how these "secret menu" functions operate and what they can do for you.
Attached Thumbnails accessing menu to increase max volume-volumesection.jpg   accessing menu to increase max volume-boost.jpg
Old 11-15-2010, 11:27 AM
08SEA300's Avatar
08 C300 Sport
My 5" screen doesn't look like that... Looks like the 08s might have less options.
I could be wrong though
Quick Reply: accessing menu to increase max volume
