Bluetooth just hangs with static now
Old Nov 15, 2010 | 09:31 PM
poisonpill's Avatar
2018 E43, Hyacinth Red
Been running the Blackberry Bold with no problems the last few months via the bluetooth in the car. The other day I get in the car and the phone screen on the nav says Unknown and all I get is static. There's no call happening yet I can't "hang up" or disconnect in order to get the stereo back. I killed the bluetooth connection on the phone and things went back to normal... until I enable the Blackberry again.
I've re-paired the connection several times, including having the car listen for the phone and vice versa, both with the same outcome. I've even reset the entire stereo but to no avail.
Any ideas what's going on?
Old Nov 22, 2010 | 03:11 PM
poisonpill's Avatar
ok, figured it out. Under the bluetooth settings on the Bold was an option for Audio. I unchecked it and everything's working normally again.
Not sure how this option got added/changed in the blackberry but hopefully this helps others.
Old Feb 19, 2011 | 02:28 PM
stogge's Avatar
2014 e350 Luxury
Hmmm... Having the exact same issue... Has anyone else had this problem and have a solution>?
Thanks!
Old Feb 19, 2011 | 04:08 PM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
try by removing the battery from your blackberry, some times the phone needs to reset, I had the same problem when I had the storm
Old Feb 17, 2012 | 11:47 AM
Markom's Avatar
2010 C300 Luxury
I can confirm - removing the battery from my Blackberry Storm 9550 did the trick! Thanks!
