tire pressure question
I have a 2009 C class with the 17 or 18 inch AMG wheels... I bought new 16' snow tires from tire rack... do I keep the new snow tires the same tire pressure used for my AMG wheels? .... which was like 32 in front and 39 in back... or do i need to find out a different tire pressure for my new snow tires?...
Thanks...
Tire pressure is determined as part of the overall handling and load characteristics of the car to provide the best handling. Even if you change your 3 season tires to another model, you would also maintain the MB recommended pressure.
As pressure increases, the part of the tire on the ground (the contact patch) narrows slightly increasing the relative pressure per square inch, which is helpful during the winter. The increased pressure in the tire also increases the downward force. Conversely, it is not helpful to reduce pressure and widen the contact patch, as that essentially reduces and spreads out the downward force, and reduces the pressure per square inch. To experience this personally, stand up and experience how your right foot feels when you lift your left foot...the right takes all (instead of half) the pressure of your body weight, pressing down on the floor more, but it would be more difficult for someone to slide that single foot along the floor. More pressure per square inch improves traction, which is why long ago folks started tossing heavy bags of sand in the trunk!
Hope this helps make it more understandable.
Should you check when hot since that's operating temperature...I don't get the point of checking when cold if that's not how they perform.
Thanks...
Pressures for 17s for example, differ from 18s.
For example, if the front tire spec is 32psi, and you only achieve that when the tire has been run at highway speeds for prolonged periods, the cool inflation will be significantly below the spec, perhaps in the high 20s, which is severely under-inflated as you drive around town. This really becomes a matter of following the instructions which came with the car and tires.
I am not sure how to make this any more understandable....anyone else?
