Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
- Mercedes-Benz C-Class: How to Adjust Windshield Washer Nozzles
Step by step instructions for do-it-yourself repairs
Windshield washer spray nozzles?
'15 E350 4M Sport
1. Are the nozzles heated in cold weather?
> I could not locate in forum search or Operator's Manual.
2. Nozzle adjustment?
> They are really tight and I seem to overshoot when tapping one side or the other of the floating round piece of plastic where the fluid shoots out.
I have a C180 2010 Avantgarde and they are not heated. I know because mines were frozen last winter.
For the adjustment you may want to use the special tool under Artkl. nr. 001 589 02 16 00, which is also used by the service. I would buy one, if I were you, to save me the trouble of going to service each time. It should cost around $10 or so.
'15 E350 4M Sport
Thanks. Where can I get a hard copy of that article? Anyway, my guess is that they change the nozzle design (and therefore the required tool) between generations.
Does anyone have details about W204 C300, whether the nozzles are heated?
2012 C250 Coupe
To be honest, I don't know for sure. But this car ad listing has it listed as an option under convenience features, so I guess it does: http://www.payneautogroup.com/2010-M...-TX/vd/6002711
I know that my Escalade has heated windshield washer fluid, but they recalled it and removed it and I got a $200 credit because it was catching fire... Lol
'15 E350 4M Sport
'15 E350 4M Sport
The MB parts guy said the tool above is $23 and that it "should" work on the C300. After some searching, I found some other tool part numbers, including BMW. I have a feeling they might all be the same or similar. Does anyone know if the MB tool is the same as the HAZET 4850-1?
BTW, if I can believe the parts guy, he said the nozzles are not heated but the reservoir is, supposedly using radiator coolant that passes close to it somehow.
