W204's and offsets of wheels
#502
'11 C350 '13 F150 lariat
W204s have a minimum load carrying capacity of 91 or 92 on the front tires. This means to adequately hold the load and load transfer for the fronts per OE psi, they need to carry @ 1032-1134 lbs each. A 215/35ZR19 only comes in a 85 load rating, even extra load. It is an OE REQUIREMENT for load to meet or exceed the OE load rating. If you don't, then the tire cannot hold the load of the car even at max psi. It causes the tire to overheat substantially, which leads it to do absolutely nothing it says it will do. I wouldn't let anyone I know ride in a car with those tires, and quite frankly, any respectable, educated tire installer should deny it as well. 225/35ZR19 will meet all needs and do you well.......
#503
my rims are coming in tomorrow. I have a quick question. The wheel offset in the rear is et48 19*9.5. I was wondering if I can run a 275/30 in the rear with out rubbing. I willbe lowered on the HR sport springs.
#506
with a +48 out back u will slightly rub the inner fabric on the passenger side on bad bottom outs only. Im slammed on 265/35/19 w skinny falkens and I rub once a while a tiny bit on that side. 275 will clear and 285 too w the fender, but the inner fabric is the prob. On sports u may get away w it, I did 275 stock ride height w +48 no problem, depending on the tire brand is the big deal w ur setup. 265 looks good, barely any difference w 275 ur talking 1/4 inch
#507
#508
Jimmy, My new wheels coming in couple of days. I went with 235/35/19 ET42 Front and 265/30/19 ET48 Rear. I'm planning to drop it with H&R SS springs. I should clear right?
#509
2010 E350
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
#510
I have an 09 C300 Sport with the following setup;
19x8.5 +43 offset - 235/35ZR19XL (91Y) Michelin Pilot Super Sport
19x9.5 +53 offset - 265/30ZR19XL (93Y) Michelin Pilot Super Sport
H&R Super Sport springs
Front fenders rolled
After @ 6 weeks the car is finally settled. Didn't have any rub in the front until they settled, which is when I had the fenders rolled....it's all good now...rears never rub even with 3 passengers in the back...I think next set of rears will be 275's though...ive got plenty of room....
http://www2.snapfish.com/snapfish/sl...NAME=snapfish/
#511
I've run 215/35-19 on my Audi's for years and never had any problems with being under the recommended load rating. I understand what you are saying but my tires have always performed as they should. I've always run stretched setups so that alone makes the tires out of spec. I know hundreds of guys running the same setup including my tire guy with 30 years of experience that never had one issue. It all comes down do taking risks for the sake of stance. Aggressive setups are not optimal performance but look damn good ![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
I hear ya....but just call me picky...I can't take the chance of a failed tire due to known overload and increased heat when I'm on the highway and my kids are in the back seat........not to mention I'm not a fan of spending $300+ per tire to replace due to premature wear...
#512
#514
2010 E350
I hear ya....but just call me picky...I can't take the chance of a failed tire due to known overload and increased heat when I'm on the highway and my kids are in the back seat........not to mention I'm not a fan of spending $300+ per tire to replace due to premature wear...![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
#515
Triangle TR968 235/35 R19 91W BSW All season tires
Triangle TR968 265/30 R19 93W BSW All season tires
Will this work with HnR SS Springs?
#516
I just put my vertini fairlady wheels on the car. I am lowered on sport springs. I had alot of rubbing in the rear with two people so I had to put the stock spring pad back on and now no rubbing. I am a little disappointed with the front drop. it wasent much. I like how the rear sits. could i do a supersport front spring.
#518
you r cutting it close w that. I assume u got euro's or similar w that offset, and 235/265 will work w SS setups if the tires are skinny brand. Never heard of triangle, honestly I wouldnt run knockoff tires. Not worth saving 200 bucks to get a blowout or have tire issue and trash a rim, caust thats what happens when u have rims and get a flat, wheel gets F'd up. anyway back to sizes, 225/255 is a safer bet, if they are skinny u will be fine. If it does rub a bit its on the inside of the right rear and its just fabric on bad bottom outs. I would run the stock rear pads to be safe and its better for a 4matic to not be too low, easier on the drivetrain.....
#519
cutting it close w the front, what tires u plan on running? That will clear w 35 profile in 19s, so if the MM conversion is straight up and true to size it will clear. Out back u can run a 5mm spacer to help the look. Go skinny brand to be safe. as a matter of fact everyone putting wheels on their cars should go skinny tires, its safer and less rubbing chance. Dont know why guys get wheels and then get OEM tires in low pro setups, IDK what the deal w that is?
#520
Please do not install Triangle tires on a Mercedes! I wouldn't install Triangle tires on a hot wheels car......offshore JUNK!
Jimmy, I'm running the 235s and 265s with Supersport springs with no problems at all. It's not a 4Matic though......
#522
2011 C300 Sport, 2007 Nissan Titan Crew Cab
Ok. Got my 19's on the other day, 8.5 up front et45 9.5 rear also et45. I really like the way the fronts sit, but the rears poke tad bit too much for me & it seems like the rear passenger pokes a little bit more than the driver's side. Can I take them to a machine shop and have them take a couple mm's off the hub to make it like an et 48-50? Or should I try a rim/tire shop? How will I know how much meat they can take off without affecting the integrity of the rim? Sorry for all the questions, and I am at work 'til Sunday morning without my car, so I can't post any pics 'til then.
#523
10 E63, Sold -07 E63
You will have to measure how much meat you have left from where the wheel bolt seats to the back hub face. You may be about to remove 30thou from the face but not much more. Again a good machine shop should be able to determine and measure how much to remove. If you are using factory bolt lengths, you won't be able to remove much, but if your wheel requires much extended bolts.. then I suspect you should be able to shave off at least 1mm.... or more.
#525
you can go much more than that, I have two sets that I did 5mm on one and 8mm on the other. We are talking wheel hubs here, NOT the cars hubs, not sure people reading this know what I/we mean here. Most wheels are almost identical, they are just cast/forged w a thinner hub/boltup thickness to adjust for offset. Think about forged wheels, its the same wheel but they can make any offset you want, HOW? They adjust the cast and machine the wheels. U can simply call around and find a highend or good machine shop that does CNC routing. They will mont the rim and buzz off whatever u need and or what they think is safe. My BRABUS wheels were 30 out back and 35 out front, I did 5mm fronts and 8mm rears and I could have went more out back they are thick as hell..........
