Water leaking into cabin??
Old Jan 7, 2011 | 06:46 PM
matrish's Avatar
Range Rover
Rained hard yday and to my disbelief one side of the rear seat floor is completely soaked! Any ideas on what caused this to happen? The rest of car the car floor is dry just one side of the rear floor is wet. Its a 08 c300 with a pano roof if that helps any....thanks guys
Old Jan 7, 2011 | 10:58 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
If the door/window or roof was not partly open I would try to replicate the problem with a very heavy hose down to see where in water is coming in.
Old Jan 8, 2011 | 12:41 PM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
Check the door seal otherwise take it to the stealer for warranty repair.
Old Jan 8, 2011 | 01:32 PM
noka's Avatar
'24 Porsche Macan
Clogged sunroof drain perhaps?
Old Jan 8, 2011 | 10:51 PM
ZeroSeVen's Avatar
Mercedes Benz C300 Sport
There should be some signs where all that water came from... Check the window seals if there is any moisture or leak marks inside... Check the pano roof seals for any signs as well
