Will this wheel fit?
2011 C300 4MATIC
I'm looking at a set of AMG replicas with the following specs:
Wheel Size: 17x8
Bolt Pattern (PCD) 5-112mm
Wheel Offset +40mm
CB: 66.6mm
Going to put the original 225 tires on the front and the 245 tires on the back. I've seen a picture of these fitting but I wanted to get some additional opinions. Thanks.
Wheel Size: 17x8
Wheel Offset +40mm
CB: 66.6mm
2011 C300 4MATIC
I agree with you about the 18s or 19s, but it's a 3 year lease and I'm looking to just put the all season tires on these 17s to avoid spending a lot of money. Right now, the original wheels are being used as the winters. These replicas would be my summers.
That size is a tad low on offset, but should be ok. Here is what ET44 looks like.
https://mbworld.org/forums/c-class-w...g-17-reps.html
2011 C300 4MATIC
The 18s or 19s may give you an appearance boost, if you happen to like that. But, from a performance point of view, the 17" size is optimal, so enjoy the driving!
Yes, and it seems that 4mm (which is .15"...fifteen hundreths of an inch!) should be tolerable, both front and rear, compared to my photos, and some would even consider it a bit more "aggressive" looking.
When you get them on take pics and post them in the offset thread.
https://mbworld.org/forums/c-class-w...ts-wheels.html
2011 C300 4MATIC
Thank you so much for all your help and your car looks awesome. If I had your car colour, I would have grabbed those wheels as well.
I've got a set of 17" AMG that came from my 2009 C350, they have the original Conti tires with 25k miles on them and plenty of life. looking for $600 plus shipping from Nor Cal.
https://mbworld.org/forums/wheels-ti...-oem-rims.html
Everyone keeps telling me I need new rims but I love the way the 17" AMG wheels look on this car.
i'd be very careful with the sizing, since you have a 4matic. having too wide a
differential in rolling distance between front/rear tires can screw things up
mechanically...as well as electronically. proceed with caution.
