Steering feeling getting stiff.
Sounds as if the power steering pump could be failing.
Is the belt drive not slipping on the power steering pulley ?.
Do you have any power steering assistance when the car is at standstill ?.
Lift the bonnet when the engine is running so you can hear what is happening when you turn lock to lock .
Could be the end of lock relief valve not seating properly.
Sounds like a visit to the workshop.
Good luck.
Thanks for your reply. Yes I still do have power assistance when the car is at standstill but it has been noticeably less assistance. Takes more effort to go lock to lock and I just noticed this morning that when I try to go full lock, the car seems to make weird noises and the steering seems to struggle to get to full lock. The belt and pulley all still looks ok and it seems to be spinning normally with no abnormal sounds or such. So I'm guessing it's the power steering pump?
You could also have mechanical stiffness in the steering rack ,joints or suspension bearings ( strut) & bushes which is making it difficult for the power steering to overcome.
I would jack up both front wheels & turn the wheels both with the engine running,, without the engine running then try turning the wheel by the wheel itself lock to lock. This excercise may show up any mechanical binding.
Best to let the experts take a look asap.It is a safety issue.
Hopefully a simple fix. Let us know how you go.
