Chrome window and door trim help..
https://mbworld.org/forums/c-class-w...etic-mods.html
http://www.stickercity.com/48-black-...for-hoods.html
Also, Trim Brite is a VERY workable vinyl. I was quite surprised at not only how well it conformed to the curve of the rear doors, but also how many times i could lift and re-seat to get nice edges and remove bubbles. If you take your time and work in 6" sections at a time in order to hit your lines and not introduce a ton of bubbles, it'll look great.
I ended up w/ only a few bubbles total, which were easily remedied with a needle. The toughest parts of the job were: a) the section under the mirrors, and b) the previously mentioned curves at the rear doors. Gotta really stretch the vinly to make it conform as best as possible. As can be seen the last pic, I couldn't get it to lay completely flat, but have since popped them. Also, any bubbles on the underside of the top of the windows will be out of view, so if you can def slack a little if it doesn't bother you.
Lastly, I didn't really use anything to lift the little rubber pieces up. Instead, I worked the vinyl in a see-saw fashion to get it under before pressing/sealing it down. Oh yeah, a new/very sharp xacto is a must!!
Here are the pics:
