Will a 5/120 bolt pattern fit ?
Old Mar 22, 2011 | 03:37 PM
hitokiri89's Avatar
2010 c350
So I found a set of wheels with the right offset and size I'm looking for but I'm not sure if the 5/120 bolt pattern will work out . You guys think it will fit ?
Old Mar 22, 2011 | 04:18 PM
itsLoonie's Avatar
2012 E350 RWD
It won't. Our bolt patterns are 5x112.
Old Mar 22, 2011 | 04:24 PM
AZN Optics's Avatar
SPONSOR/MBworld Guru
You can make it work with wobble bolts.
Old Mar 22, 2011 | 05:02 PM
hitokiri89's Avatar
2010 c350
Any danger in using the wobble bolts ?
Old Mar 22, 2011 | 05:54 PM
AZN Optics's Avatar
Wobble bolts are safe since we're hubcentric. The weight of the car is basically being supported by the centeral hub with the bolts just keeping it tight against the mount. Just make sure the bolts are seated correctly.
Old Mar 22, 2011 | 06:01 PM
Rogwp's Avatar
2010 C300 4matic Special Edition
Only if they wobble. Sorry....couldn't resist it
