EYELID PROBLEM
Old Apr 12, 2011 | 02:04 AM
ORIZABA's Avatar
2011 C350
EYELID PROBLEM
Hello forum,
I did something really stupid. I was replacing my eyelids (2011 C 350) with the LED's sold by AZN C300 (Which look awesome by the way). I started with the passenger side as advised by many here on the forum and they looked great. When I got to the driver's side eyelid.... I accidentally snapped one of the wires of the bulb closest to the center of the car. I tried to put it back together and it worked for a bit but it just shut off and won't come back on again. I put in the stock bulb and nothing. I am not getting any error messages from the car, I am wondering if there is a particular fuse that may control these lights. I checked the fuse manual and the eyelids don't seem to be listed... Any suggestions before the dealer has a field day with me?
Old Apr 12, 2011 | 10:25 AM
jimmybrakejob's Avatar
2010 c300 4matic
Originally Posted by ORIZABA
Hello forum,
is the wire broken?? and they would be under city lights or something like that in your manual
Old Apr 14, 2011 | 01:23 AM
ORIZABA's Avatar
2011 C350
Here is a pic
Old Apr 14, 2011 | 03:28 AM
cleankutazn's Avatar
GLC 2026
Looks like you can use electric tape to wrap that up
Old Apr 14, 2011 | 03:41 AM
snarlingchicken's Avatar
2009 C350
If not, bust out the soldering iron!
Old Apr 14, 2011 | 03:57 AM
mir_m's Avatar
c220
Tape it together, switch the car off because the car will stop any power going to it replace the bulb and then start the car again happened to me aswell,
Old Apr 15, 2011 | 12:16 AM
ORIZABA's Avatar
2011 C350
Thanks ill try that. I thought i had blown a fuse or something because when I initially tape it together it worked but then it came apart. When I tried putting it back together it would not power on again. I never thought of switching the car on then off.
Old Apr 15, 2011 | 02:51 PM
mir_m's Avatar
c220
Try that mate should work let us no how you get on personally I wouldn't put these LEDs in I took mine out after they melted the bulb holder
Old Apr 15, 2011 | 10:49 PM
ORIZABA's Avatar
2011 C350
Thanks for the tip mir_m. It works now!!! What do you use now? Did you get different LED's or you put stock back on? I don't want a melted bulb holder!
Old Apr 15, 2011 | 10:50 PM
ORIZABA's Avatar
2011 C350
Just thought I would post a pic on how they look.
Old Apr 17, 2011 | 12:21 AM
ZeroSeVen's Avatar
Mercedes Benz C300 Sport
good thing it was an easy fix for yah
Headlights looks good... it matches well with your eyelids LEDs
Old Apr 17, 2011 | 12:36 AM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
Here is a pic
Use a butt conector
Old Apr 17, 2011 | 06:05 AM
mir_m's Avatar
c220
I wont say who I bought them from here don't want them to loose customers but I had to change I wiring loom which was not cheap went back to stock bulbs seller claims they were not fitted correctly which didn't suprise me my 4 yr old son could connect the bulb keep a eye out on them check the connections in a few weeks to be on the safe cheers
