Old Jun 4, 2015, 06:18 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Specifications and General Maintenance
Print Wikipost
Alarm went off and now the car has no power!!
Old Apr 21, 2011 | 12:21 AM
jdmgsr's Avatar
c350
I have a 2008 Mercedes C350 and the alarm was acting up. The key wouldn't do anything so I got into the car with the mechanical key. still nothing. I disconnected the battery and the siren was still going so I reconnected it. The siren turned off but the signals were still flashing.. two hours later when I returned the car had no power whatsoever. It wasnt the battery because I got a boost and it didnt help. But something weird is happening. One of the license plate lights is dimly lit. I think the car is in stolen mode or something like that. What the hell do I do? Is it really in stolen mode? How do i take it out? Do i have to tow it to the dealer or can I do it myself? Its not under warranty anymore because I imported the car from the US to Canada.
Thanks in advance guys!
Old Apr 21, 2011 | 05:05 PM
Acapulco Bill's Avatar
2010 C300 Sport
Sounds like a lockout between the alarm and the EIS. Others have had this problem, It is expensive to fix, the electronic modules involved aren't cheap.
Check out this thread:
https://mbworld.org/forums/c-class-w...-hate-pos.html
Old Apr 21, 2011 | 06:39 PM
acr2001's Avatar
2012 C300 4Matic
There is no mode where the alarm does what you are experiencing.
You simply have a dead battery. Check with voltmeter. Repalce battery. Find out why it died.
Old Apr 21, 2011 | 07:46 PM
jdmgsr's Avatar
c350
You were absolutely right.. i didnt think this was the problem since my first attempt at boosting it didn't work... thank u!
Old Apr 22, 2011 | 11:28 AM
noka's Avatar
'24 Porsche Macan
A voltmeter will not always show a bad battery as it can read proper terminal voltage but not be able to deliver the proper current. It typically must be tested under load.
Old Apr 22, 2011 | 11:39 AM
2010 C300 Sport
@acr2001: Is the alarm programmed to sound as a warning of a pending dead battery? Or is there actually a separate source for the alarm in case someone tries to defeat the alarm system by disconnecting the battery? Just curious.
Old Apr 22, 2011 | 12:33 PM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
I'm sure your car is under warranty, have tow to the dealer or take the battery to your closest mechanic shop have them charge it and load test it to a 3rd of its cold cranking amperage depending the ambient temperature you should be getting a result of 9.6volts. The car alarm has its own battery, even if you disconnect the battery the alarm still will go off, just another safety MB burglary feature.
