- Mercedes-Benz C-Class: How to Replace Your Spark Plugs
Step by step instructions for do-it-yourself repairs
Browse all: Powertrain
New Platinum Spark Plugs
Just joined this forum. I have a 2008 c300 sport. Bought it new summer of 08 so I've owned it for 7 years now. It has 213,500 miles on her now. Just had its 36th oil change today. It's been the best car I've ever owned. And I've been driving MB products since my first 300E back in 1990, have had Es, S, SL, and this C.
Nothing ever broke until 210,000. Ac compressor went out. I've gotten 100k miles out of brake pads. Changed front struts at 210k miles for the heck of it.
Other than the bottom drivers seat wearing out ( seams deprecating ) the interior looks cherry. Trans shifts perfectly. Performed first trans fluid change at 100k miles then every 40k since. Other than tires, (on my 7th set now,) brakes, wiper blades, changed belt at 140k miles because idler pully started squeaking ( belt still looked good ), spark plugs at 110k miles, (due to change now) and light bulbs, nothing ever went wrong with this car! It's amazing. Absolutely the best car I've ever owned.
My question is about plugs. I am no mechanic, but changing these plugs are a snap. Did it myself the first time and ngks are available on line for under 60 bucks no tax and free shipping. Just ordered them. But wondering about wires and coils??? Should I change them now??? How do you know when to do that?
Thanks for being out there you guys. This forum is really helpful. If anyone knows or has a w204 ( 08-14 C300 ) with high miles, I'd like to compare notes with you on how your car has stood up.
1. Get a magnetic plug socket from autoparts store. Helps remove plug from hole. You will need 4-6" or so extension to your ratcheting wrench.
2. NGK were the originals in mine and at 90k miles , 8 years they still looked fine . Most would recommend replacing with same ngk's - I used denso iridium with no issues
3. No anti-siEze on the thread - if you contaminate the tip of plug it will be an issue and torque spec will be wrong. (Some plugs have zinc coating already on their threads )
4. I prefer to use torque wrench versus hand tight plus quater turn - if plug is in too loose you could damage the engine and too tight will strip the head. So be careful when installing plugs in alloy head. Look up correct torque spec - I forget off the top of my head - but something like 18lb/ft 25nm ?
