question about offset
Old May 4, 2011 | 02:39 PM
Spec_Davis's Avatar
W204 Color: 090 / 1999 Honda Civic EX / 2003 Acura TL
i am looking on getting new wheels and i found some wheels for a great price but the only thing that is holding me back is the offset of +35mm front with that can you just buy 10mm spacer to fit correctly?
specs: 19' 8.5 +35 19' 9.5 +51
Old May 4, 2011 | 02:45 PM
w204nyc's Avatar
2017 C63S coupe '09 C63, '15 Durango RT, '14 Jeep SRT8
are you selling those rims that you have on? and what size are they?
Sportstick's Avatar
Another round of ICE
I believe you are going in the wrong direction. A low offset means the wheel will stick out further. Wouldn't a spacer just push it out even more?
Old May 4, 2011 | 02:58 PM
Spec_Davis's Avatar
sorry updated offset it was +40 front and +51 rear
Old May 4, 2011 | 03:06 PM
Matt_Eurojerks's Avatar
w204 C300
Those offsets look fine. depending on the tire you might rub on the inside of the rear setup.
Old May 4, 2011 | 03:08 PM
Spec_Davis's Avatar
i might go 245/30 fronts and 265/30 rears
Old May 4, 2011 | 03:48 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
That's a pretty high offset in the rear, might rub with the 265.
Old May 4, 2011 | 07:36 PM
Doanster's Avatar
C300 Sport 6MT
Stock offsets are 47mm FR/58mm RR, so you should not have any rubbing issues with the rears. Fronts... maybe, especially depending on how low you have the coilovers set. Not a direct comparo, but I'm running 235/35/19 all around on +45mm w/o problems (stock ride height).
Old May 4, 2011 | 08:10 PM
zim-c350's Avatar
2010 C350
Now not trying to steal your thread but I was looking at a similar wheel setup 19x8.5 235/35/19 and 19x9.5 265/30/19 offset for the front 45 and for the rear either 45 or 48 will this rub?
Old May 6, 2011 | 05:19 AM
bigigg's Avatar
14' CLS550
you should be fine in the rear, but the front you will rub. i would go 225/30/19
Old May 6, 2011 | 11:09 AM
jimmythegreek's Avatar
'11 C350 '13 F150 lariat
I am running 235/35/19 with a 45mm offset in front (8.5) and 275/30/19 40mm offset in rear (10"). My car sits low when in M mode and the handling turned on and I dont rub at all. I test fit 285 and they just barely rubbed in the rear.
The 40 in the front is tight, but on my last C I ran 225/40/18 on a 35mm offset in front w no rub so you will be fine up front with 40 even on a 235. If you go 225 up front go 255 on back to match the stretch, 265 on back will be almost no stretch and wont match sidewall profile
