Old Jun 9, 2015, 04:36 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
Print Wikipost
sub and amp install
Old May 6, 2011 | 11:12 PM
GobesC300's Avatar
2011 C300 sport
sub and amp install
I am going to install a sub and amp in my trunk next week. The professional wants to do line level inputs to the amp from the back speakers. I am worried the amp is going to mess with the stock speakers and maybe even the car's electrical system. Should I be worried?
Old May 6, 2011 | 11:16 PM
kevinwithdabenz's Avatar
08 c350
i think you should be fine, i ran my wires from the back of the head unit and have no problems
wnunez89's Avatar
c350coupe, Gencoupe R-spec
mine was connected to the factory amp and i had issues with the amp overheating/blowing fuses and then voltage issues. but others have been fine with their set-ups
Old May 6, 2011 | 11:20 PM
GobesC300's Avatar
2011 C300 sport
Did you have a professional install? The head unit is incorporated into the entire dash...seems like a nightmare
Old May 6, 2011 | 11:48 PM
M-bENZ's Avatar
Corrolla
tap it to your stock sub or directly to your stock amp.
Old May 7, 2011 | 12:08 AM
wnunez89's Avatar
yes sir pro installed. their biggest issue at the time was i was gonna switch out all speakers to DD component speakers but i opted out when they said it was gonna be a pain with all the fiber-optics
Old May 7, 2011 | 12:10 AM
wnunez89's Avatar
i just realized your in jupiter call serious autosport ask for Evan, tell him Will with the c350 told you to call, he'll take care of you. 561-429-6900
Old May 7, 2011 | 12:18 AM
GobesC300's Avatar
2011 C300 sport
Wow, good looking out Will...Thanks
Old May 7, 2011 | 12:25 AM
wnunez89's Avatar
no problem, always out to help a local MB enthusiast
Old May 7, 2011 | 12:20 PM
Richie999's Avatar
2011_C350
I need exactly what Gobes is after but cannot find any legit installers in PHX...
Old May 7, 2011 | 12:28 PM
howie's Avatar
01 CLK 55 AMG
that's normal to do it this way, shouldn't be a problem at all. You have to use a line level input either way so where it's located doesn't really make a difference.
Old May 7, 2011 | 12:58 PM
Richie999's Avatar
2011_C350
Gang - does this type of install impact the factory Mercedes warranty?
Old May 7, 2011 | 03:54 PM
howie's Avatar
01 CLK 55 AMG
not if they don't know about it. Plus it has nothing to do with any of the factory equipment. You're simply tapping the pos and neg speaker leads of 1 speaker just to get signal for the RCA on the amp. Shouldn't affect your warranty at all but u know how that goes once u have an issue and are at the dealer
Old May 8, 2011 | 10:49 AM
Acapulco Bill's Avatar
2010 C300 Sport
Subwoofer input: if its DIY taking the signal from the right rear speaker, for under 150 hZ it hardly matters, and run it to meet up with the hot 12V line at the right side of the trunk.
For a pro install, might as well get the full Monte with the line level outputs.
Of course you are going to replace the stock speakers with Infinity Kappa's (unless you are adding a sub to the HK)?
Old May 8, 2011 | 12:15 PM
08 c350
Originally Posted by Acapulco Bill
Subwoofer input: if its DYI taking the signal from the right rear speaker, for under 150 hZ it hardly matters, and run it to meet up with the hot 12V line at the right side of the trunk.
can you share a link to the kappa you recommend?
Old May 8, 2011 | 02:55 PM
AskDrTodd's Avatar
2011 C300 Sport
Which is the best speaker wire to tap for a sub input, and where is that wire? Is there one in the trunk?
Old May 8, 2011 | 05:35 PM
jimmythegreek's Avatar
'11 C350 '13 F150 lariat
If you have HK you can tap in the trunk for sub input, the stock sub in middle is dual voice coil, just steal it from there and eliminate its power, you have real subs now.
If you have basic audio, you can either install a low level adapter behind the head unit and run RCAs thru the car, OR you can jump from the rear speakers in the B pillar or below them. I did B pillars on mine. The head unit comes out w special tool or a wire clothes hanger with the proper bends, if you search theres a thread showing removal in the DIY area
I used a MTX reQ so I could add another amp and did it in the trunk so I could adjust it otherwise I would have done the head unit in back
Old May 8, 2011 | 09:22 PM
2010 C300 Sport
@kevinwithdabenz: A long thread, but tons of info and some photos.
https://mbworld.org/forums/c-class-w...r-upgrade.html
Old May 9, 2011 | 06:26 PM
howie's Avatar
01 CLK 55 AMG
any speaker lead will provide signal
