Hankook K110 275/35/19 too wide??????
Old May 13, 2011 | 03:20 PM
zim-c350's Avatar
2010 C350
I was looking at the roderick rw2 wheels, and had spoken to something and they told me 275/35/19 would fit in the rear without any rubbing is this correct? I dont plan on lowering the car at all. He told 245/35/19 in the front. What do you think about this setup, also are the Hankook K110 a good quiet tire?
Old May 13, 2011 | 04:16 PM
kendricksoares's Avatar
mercedes benz c300
not sure if the tires are good or not zim, have had good experiences before with hankook tires, but i believe the size will work with no problem
Old May 13, 2011 | 04:29 PM
itsLoonie's Avatar
2012 E350 RWD
What's the width of the wheels? I say it should work if you aren't gonna lower it.
Old May 13, 2011 | 04:37 PM
Sportstick's Avatar
Another round of ICE
Here's a resource for you to study....
http://www.tirerack.com/tires/surveyresults/index.jsp
Old May 13, 2011 | 05:57 PM
zim-c350's Avatar
2010 C350
Ahh thank you! I am not looking to lower the car at all so 275/35/19 245/35/19 should fit prefectly fine?
Old May 13, 2011 | 09:57 PM
jimmythegreek's Avatar
'11 C350 '13 F150 lariat
zim im running 275s on 10 inch rears w no rubs 30/19 w a 40mm offset. 35 is too high if you ask me. front is 8.5 w 235/35/19 45mm offset. no rubbing and I clear. I test fit 285 and it slightly rubbed inner well fabric not fender tho. I wouldnt do 245 front if yours are 8.5 cause sidewall wont match the stretch in the rear. look at my wheel pics if you wanna see what they will look like. Im running carlsson 1/16s
Old May 13, 2011 | 10:46 PM
I am Jeff's Avatar
Steel Grey Metallic C63!!
Your car needs 275/30/19's, not 275/35/19. 35's are too tall.
