My parametric EQ settings
Old May 14, 2011 | 06:31 PM
cleankutazn's Avatar
GLC 2026
Here is a pic of my settings for the non HK system, made a huge difference in extending the treble clarity especially for the CD player. Remember you have to set it for both left and right channels. 1st pic is the front and 2nd pic is the rear. For the rear I tried to extend the lower bass frequency as much as possible.
Attached Thumbnails My parametric EQ settings-parametric-eq-front.jpg   My parametric EQ settings-parametric-eq-rear.jpg
Old May 14, 2011 | 11:57 PM
Hzkasbarian's Avatar
2012 Mercedes c250
thanksss alot man
Old May 14, 2011 | 11:58 PM
Richie999's Avatar
2011_C350
CAn this be done on cars with the flip up Nav?
Old May 15, 2011 | 01:42 AM
Imageboi's Avatar
c300
nope audio 20 only maybe the 50 but for sure the audio 20 but ye i'm going to have to try your settings and see if any difference..
Old May 15, 2011 | 05:45 AM
GLC 2026
Originally Posted by Hzkasbarian
thanksss alot man
No problem..let me know if you hear a difference.
Old Jun 27, 2011 | 08:45 PM
dasinner's Avatar
c300
hi there before i mess arround with eq can you temme what is the difference you feel with this setting ...
Old Jun 27, 2011 | 09:54 PM
caligreenzzz's Avatar
W204
thk you very much....
Old Jun 27, 2011 | 11:22 PM
dasinner's Avatar
c300
did u try the settin ?!?!? what is the main diff ...
Old Jun 27, 2011 | 11:51 PM
W204
tweeters sound much better, i havent driven around but from what ive heard its much improved...
Old Jun 27, 2011 | 11:52 PM
dasinner's Avatar
c300
is it more
louder
clear
more or less bass ?
Old Jun 27, 2011 | 11:55 PM
W204
first id say my **** sounded fine as is...i didnt even know bout this ****, i would say it sounds much much better, but im the type who still has the treb and bass at +10....my **** is all stock and now after the tweeks its soundin real nice....**** if you dnt like it then put back all the old setting, just write it down on paper....but i would mos def suggest tryin it
Old Jun 27, 2011 | 11:57 PM
dasinner's Avatar
c300
that what i was planning to do ... to noted on paper in case i changed my mind but fo shizo il try this and let yall know ... htnaks
Old Jun 27, 2011 | 11:59 PM
W204
yeah let me know what you think cuz i think this **** is on point....
Old Jun 28, 2011 | 10:53 AM
emdem's Avatar
2013 E550 Coupe
OK let me ask this - I change the settings and decide I don't like the results, is there anyway to get back to the default settings?
_________________________________________________
Nevermind - pencil and paper will do...
Old Jun 28, 2011 | 12:22 PM
Acapulco Bill's Avatar
2010 C300 Sport
Could have gotten the same results just with the Treble tone control, actually. The Bass also, there is zero response from the $1-for-the-8-speaker-set stock speakers @ 40 Hz. If you really want a difference in the bass, set the Q = .8 centered around 80 Hz. But then again the Bass tone control basically would give this result.
Parametric equalizers are to correct specifically narrow "peaks and valleys" in the response. The way the equalizer is used in this illustration, is almost identical to the treble and bass tone controls. The double-overlap of the 11k Hz and 14k Hz boost with an extreme Q and +5dB boost... why? The cheap stock plastic-dome tweeters will just spit at these settings.
Here is some good info on how a parametric equalizer works. Hope it inspires some to download spectrum analyzer software for their iPhone, make some measurements, and get better sound from the stock speakers.
http://recordingwebsite.com/articles/eqprimer.php
Old Jun 28, 2011 | 12:29 PM
W204
Originally Posted by Acapulco Bill
Could have gotten the same results just with the Treble tone control, actually. The Bass also,[/url]
naw i couldnt...these setting make my system sound much better,much....
Old Jun 29, 2011 | 07:08 AM
GLC 2026
No problem, glad it helped you out.
Old Jun 29, 2011 | 07:11 AM
GLC 2026
I just did what sounded good to my ears.
Old Jun 29, 2011 | 08:50 AM
2010 C300 Sport
The Parametric EQ in some of the W204's is certainly a pleasant surprise. However, it is difficult to adjust (one cannot hear the changes until after the whole process is completed, a several minute ordeal), and you cannot go and do a live "A vs B" comparison afterwards. Its like putting way too much salt on one's food, after it is done, it's difficult to undo.
That said, I am glad cleankutazn is pleased with his result, although my personal preference was to forget the EQ and go straight to ripping out and replacing the horrible stock speakers with something clearly superior. So satisfactory was this $200 investment that the only change to my EQ was to remove the bump at 2.3k Hz the MB factory programs because of the suck-out between the tweeter and woofer in the stock speakers. And until I get a real-time 1/3 octave spectrum analyzer to go poking around to see where the deficiencies in the frequency response are, the EQ lies dormant to prevent my misuse.
But as dasinner asked, should he try and change things? Of course go ahead, and if at the end of the day the stereo sounds "better" to you, fantastic! Although the stock MB speakers will always sound terrible whatever correction is done. IMO.
And one hopes cleankutazn doesn't own a puppy, does he now get chased down the street by dogs? Just kidding, but that IS a lot of boost at two narrow frequencies that 60% of us can't hear. I'll take my sound FLAT, please, and not to much SALT, thanks.
Old Jun 29, 2011 | 10:07 AM
JaCe88's Avatar
GLE 300d (v167)
Being a bit noob here but howcome this setting is only available on audio 20 and not the COMAND systems?
Old Jun 29, 2011 | 10:09 AM
2010 C300 Sport
Hmmm... this chart makes me want to go running down to an audiologist Doctor and discover the truth about my OWN hearing. How much damage do earbuds do? FYI.
Old Jun 29, 2011 | 12:01 PM
W204
A few years ago while conducting Bizet's opera "Carmen" for a concert with a video recording.
thats when i stopped reading....
Old Jun 29, 2011 | 03:47 PM
fefo25's Avatar
2010 C300 Sport 6 speed Steel Gray
Would these settings work with upgraded speakers?
Old Jun 29, 2011 | 06:23 PM
GLC 2026
With upgraded speakers I don't think you would need these settings, but trying wouldn't hurt.
Old Feb 18, 2012 | 04:41 PM
1sik_c300's Avatar
2011 c300 sport
Great settings thanks. Got way more trebble out of it..what settings would i change to get a lil more bass??
