Tire pressure and navigation question
Old May 18, 2011 | 12:57 PM
NJBenzC300's Avatar
2011 C300 4MATIC Sport
Hey everyone. I noticed my 2011 c300 4matics front tires look low. I took thecold pressure and it's the same as on the drivers side(stock 17's) 235/45/17. Has anyone else run into this issue? It states 30psi cold but, the two front look low.
Another question I have is can you lowerthe navigation volume cause it's like she's screaming at me.
Thanks in advance
Old May 18, 2011 | 01:11 PM
mbcoolguy's Avatar
c300
with the engine up front its heavier so yes the front tires will look like that. as for the navi. i would like to know the same thing as well.
Old May 18, 2011 | 01:12 PM
NJBenzC300's Avatar
Yeah and I have the 7 speed trans but doesn't every 4matic?
Old May 18, 2011 | 01:27 PM
gwai_jai's Avatar
2010 C300 4MATIC
you can change the volume of the nav only when she's talking....any other time, you're changing the volume of the audio
Old May 18, 2011 | 01:29 PM
Matt_Eurojerks's Avatar
w204 C300
I was trying to figure this out the other day.
Old May 18, 2011 | 01:30 PM
NJBenzC300's Avatar
So, when she talks just lower the volume and it won't adjust the radio volume?
Old May 18, 2011 | 01:31 PM
Sportstick's Avatar
Another round of ICE
Thanks in advance
Short of something dramatic, such as a flat, one cannot judge pressure on radial tires by looking. It used to be easier with old bias ply tires, but no longer. If you have a good, reliable gauge, that is the final word.
Old May 18, 2011 | 01:36 PM
NJBenzC300's Avatar
Thanks sportstick. I just purchased the car and prior I had a 2008 VW GTI with the same tires. The MB is way heavier and way better.
Old May 20, 2011 | 02:34 PM
icanectc's Avatar
2016 C450 AMG
You are correct! The mute button also works while the nav is talking as well.
