Help I just drove my W204 for a kilometer with parking brake on
Just wondering would the main braking system be damaged and should I take my car to the dealership to get it checked up? I think the parking brake was applied about 4 - 5 "clicks" deep.
Even if you are parked on an incline, there is a "Hill-start assist system" that will apply the brakes on startup, until you press the accelerator, either in Drive or in Reverse.
Congrats on your C250, ALL MB engines should have this kind of performance - 204 HP from a 1.8L engine and 229 lb-feet of torque, MORE torque than the C300, same acceleration and should handle better because of the 216 lbs in weight saved. Imagine 4 bags of concrete on your W204's hood!!! Thats the different in weight between the C300 and the C250.
Check the rear axle seals for any leakage. I had to replace them, but that was a different design.
I also have an audible alarm if I start with the parking brake engaged.
.Contacted the dealer today and they advied there shouldn't be any problem but for peace of mind I can let them have a look.
