Trunk badge removal?
Old Jun 30, 2011 | 08:59 PM
Norm01's Avatar
2011 E550 Coupe
Anyone know how to remove the trunk star badge. I have gained access to it, it looks like chrome studs through white plastic rings. Do the studs push through the rings or do you pull the rings off individually with pliers.
Old Jun 30, 2011 | 09:39 PM
Thaa kiid Jlee's Avatar
2011 c300 4matic
use something flat and it pops right out
Old Jun 30, 2011 | 09:43 PM
xXHotelCrazyXx's Avatar
2008 W204 Sport
Yes, peel back the trunk liner and use a phillips screw driver and stick the tip in each stud and push the badge out...dont use a screwdriver to pry it off from the outside....you risk breaking it and scratching your paint. Do it the right way with no regrets
Old Jun 30, 2011 | 10:51 PM
Stevedotmil's Avatar
W204 2010 C300 Sport/6M
I just used my MAN fingers and pulled it off.
Old Jul 1, 2011 | 09:04 AM
AskDrTodd's Avatar
2011 C300 Sport
hahahaha WIN!
Seriously though you could probably get under it with floss or something? It isn't glued or taped or screwed on.
Old Jul 1, 2011 | 09:47 AM
Bayou Benz's Avatar
2009 C300 Sport; 1986 VW Golf GL; 2008 VW Jetta Wolfsburg; 1979 VW Beetle cabriolet; 1997 Chevy 350
I tried 40 lb. fishing string it kept popping had to drop the liner.
Old Aug 8, 2011 | 09:15 AM
tivoliman's Avatar
E450 2019; 560SL 1986
Great thread - all worked well
I removed my Mercedes emblem (circle with three point star) right off the trunk - pushed with Philips Head screw driver - no issues - worked great in about 45 seconds.
The E 420 logo was removed with dental floss. Knew there was a reason my dentist gave me that stuff. Sawed the floss back and forth like the hygienist does, and the individual emblems just popped off.
This thread saved me $$$$$.
I know you know what the emblem looks like, but wanted to clarify.
